TA22 celica diffs are the same width as KE30. You will need to swap the mounts (coil spring on celica to leaf spring on corolla). Also RA23/28 which I think are a touch wider but nothing to worry about. Again mounts need to be swapped.
If you want unbreakable you could use early hilux. Probably a bit of overkill though.
Another common one is R31 skyline but this can be a bit pricey as it needs to be shortened.
