Results 16 to 30 of 37
Thread: Suitable diff for KE30 with 4AGE
    Default Re: Suitable diff for KE30 with 4AGE
    Quote Originally Posted by faulksy
    Any reason for the diff swap? Have you broken the diff? Have yopu broken any. Only asking as can see the issue with the standard diff aslong as its the borg warner and not the banjo (much weaker). The ke30 diff should be able to handle the extra power and torque aslong as its not abused extensively
    I can vouch for the banjo being very weak, Well i think mine was abnormally weak. Just before i put the rolla in to start the conversion i thought.. hmm ill see if i can do a line locker on the grass. rev it up, dump the clutch, touch the brake and SNAP! No more go.. Then i had to push it in the garage.
    I got my diff of Dom-AE71 and i think he got it of someone else. It had the corona st141 discs on it with calipers. Maybe you could do that?
    Junior Member Grease Monkey faulksy's Avatar
    The other issues i find with the banjo's some of them don't even whine before going bang No warning, just driving along and then no diff. Can get away with BW whining before eventually breaking. A whine certainly makes sure you ease off so you can get home
    Metal Guitarist 1st year Apprentice AE35's Avatar
    What faulksy said. (Good advice by the way faulksy. Will be taking that into consideration for my panel van). If you're going to be putting out more power than stock, by all means, a diff upgrade is definately in order.
    Good thing I've read about the TA22 celica diff's is they are quite suitable for a TRD LSD centre which will outlast a falcon/commodore style cone-style LSD.
    Junior Member Grease Monkey 78Rolla's Avatar
    faulksy: I haven't broken the diff - but I thought it would be wise to change over the diff when i upgrade the engine...I was thinking the TA22 diff because I was going to use the TA22 front struts for the brake upgrade, and thought i could keep it consistant with the wheels. Or do you guys know of any better solutions? (cheaper/easier)
    P.S how do i tell if i have the bango already?
    Junior Member Backyard Mechanic Hokey's Avatar
    Have a look at your diff. i am sure that the BW have a octagonal backing plate and they will say borg warner on the diff pumpkin. i am not sure what banjo diffs look like though. if yours doesn't say BW then i guess it must be a banjo
    -Calvin
    thats a correct describition of a BW. the banjo are rounder housing.
    can also tell thyem apart from the size of teh drums. BW have the large drums
    also (could be very wrong) all aust build ones had BW and the jap ones had banjos
    celica would keep same stud pattern so thats no a bad idea but of wanted better diff pintaras have same stud pattern. also pintara have huge rear discs. bigger then the commodores. also its not hard for someone that converts differents to change the stud pattern.
    a wise decision to upgrade the diff if going to update the engine. otherwise going to need done anyway. the celica is probaly your cheapest upgrade and be acceptable if not abused
    i have a commodore diff in my ke30, its been shortned with 4 11 gears and a mini spool put in. so far so good, oh yeah my rolla has a sr20 in it
    slippery when boosting-ke30 sr20 underway
    Quote Originally Posted by shy_77c
    That would be a BW 78 series. Lots of gears and options available. eg. LSD, spool
    And whoever rep'ed me and asked for this theard "22rep + this rep = what?" Your rep is worth 2
    sa
    Faulksy towed a couple of my kerolla's back in the day when I blew my diffs.
    Banjo's are so weak. Even abusing them with a mere 4k will snap spiders.
    hilux & r31 are too heavy for a ke & the amount of torgue a 4age produces doesnt warrant this conversion imo....too much unsprung wieght will turn your handling to shit
    i know of a ke than ran a 120y diff behind a 3tgte that saw constant abuse & it held up remarkably well
    my pick would either be T, G or F series toyota
    Quote Originally Posted by Variable
    where do you get this theory from? it aint no 9 inch. now thats overkill. i noticed no difference in handling with a BW78 over the standard diff
    just to let you know im trying to source some ra40 front struts for my ke30 upgrade.
    see the document here : http://home.swiftdsl.com.au/~bradw/FBU.html
    I have a set of ta22 struts and i was going to use them but theres not much of an upgrade there. The disc are minimally bigger. Also i read(havent tried) that the ta22 struts need a bit of mod done to the control arm. This is why i chose the ra40 struts and we'll see how easy they go in.
    Hilux diffs are G or F series. jsut not sure which one
    hilux are F series (i think) but i was referring to the F series Crown. R31 is actaully an alright option but for the cost i think you could do better
    faulksy, i guess it depends what you want out of the car. I'm a little biased towards circuit racing so i'd try to use weight to my advantage. A t series diff would be better suited to a 4a...strength wouldnt be an issue & it'd be 20kg lighter than a hilux. The more weight you're carrying on a live axle the worse your handling will be...thats just physics. Probably not much on a daily driver but if you want to milk every bit of performance you can then it seems logical to keep unsprung weight down.
    in the end i guess its whatever floats your own boat
    fwiw i've had a t series behind a turbo 4a for a few years & never had any problems
    cheers thats the soprt of info i was looking for. i knew a t series would be strong enough for a 4age but was unsure on if it had the strength for forced induction. i guess i still feel more confident with a BW78 series if launches (ie. drags) were involved due to its extra size but on a track its extra dead weight
    good contribution Variable + rep for you
    the opinion is starting to swing. maybe a celica diff to start off with as its the easiest conversion and if not stronger enough in the future im sure you could easily sell it to a person with a ke30/55 as already modified to bolt in and get your coin back
    Last Post: 17-06-2008, 09:53 PM
  2. T series rear end diff centre change guide (warning, pics!)
    Last Post: 31-05-2007, 12:57 AM
  3. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
  4. Diff Question
    By mlaser in forum Tech and Conversions
    Last Post: 17-04-2006, 09:13 PM
  5. Most suitable sized exhaust for 4age 16/20v
    Last Post: 09-02-2006, 06:48 PM
