Results 1 to 8 of 8
Thread: 1jz jza70 RPM pinout/TACH output
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    Default 1jz jza70 RPM pinout/TACH output
    firstly i have searched and couldnt find anything
    autometer 3 3/4" tacho/VDO 4" Tach in z20 soarer
    have looked at the ecu pinouts, tried both rpm outputs - nothing
    tried the RPM wire on my greddy emanage - nothing
    and also tried the wire on the first coil?? - nothing
    cant get any readings, whats my problem?
    thanks
    87' z20 Soarer - 1jz Gt35r -
    Default Re: 1jz jza70 RPM pinout/TACH output
    Firstly, the tacho output is off the ignitor.
    Secondly, are you sure the tacho works? Does it have different settings or inputs for positive or negative pulse, high or low voltage signal, etc?
    I'm curious as the what these 'RPM' outputs on the ecu are?
    Which pins were they?
    But anyway, as Mos said, the tacho is driven directly off the ignitor.
    Temporarily run a wire from the IG- pin in the diagnostics box to the tacho, see if that works.
    TAS
    as per http://i2.photobucket.com/albums/y5/...cu_diagram.jpg
    i tried both 17 and 23.
    which wire on the ignitor do you wire to?
    thanks
    IGF and IFT are not tacho outputs, they are signals between the ECU and Ignitor.
    While they may be the same frequency to the tacho signal, they are not the correct signal.
    The ignitor tacho wire is the same wire as the IG- pin in the diagnostics box.
    It will also come through the firewall with the rest of the wires.
    One of maybe 2 black wires.
    TAS
    found the diag box, its in a prick of a spot because the lead is really short and with my custom plenum it cant be pulled through the ports.
    it seems the IG pin has a spade like connection, any inparticular?
    is the wire visable/easier accessed in the engine bay?
    That wire will go to the ignitor, as well as through the firewall. It may be easiest to get to it from behind the glovebox.
    TAS
    thanks a heap +rep
    got it working!
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 05:27 PM
  2. 1JZ > 2JZ Map Sensor Upgrade Myth Burried.
    By JZA70 R in forum Tech and Conversions
    Last Post: 14-11-2008, 08:45 AM
  3. 1JZ performance head build. Advice/help?
    Last Post: 09-07-2007, 08:08 PM
  4. 1jz to 2jz
    By HIZOKU in forum Tech and Conversions
    Last Post: 30-11-2006, 06:52 AM
  5. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
