Is this going to be a dedicated track car? Why do you think you need such crisp throttle response? It's in a 70 series Supra? My gut instinct tells me you should just use a couple of nicely sized roller bearings with nice intake and exhaust manifolds to achieve what you are after.Originally Posted by ReQuieM
This is going to be painfully expensive. You'll need to make a manifold (you can't use Ed's because it won't bolt up to your 1JZ). Then you'll need to buy 6 ITBs (or 3 pairs) and associated linkages. Then you'll still need to make some sort of "plenum" or sealed airbox.
There are plenty of throttle body options out there.
The cheapest and most ghetto spec would be finding some dead 45mm Webers, seal them off and use them. This works very well. If you are a little inventive, then you could mill off the throttle section from some SU carbs and use those as throttle plates, or the throttle section from those old shitty single barrel carbs can also work fine.
Simplest would be the GTR 45mm throttle plates - you can bore them out if need be and get larger throttle plates put in them but then that negates how cheap they are. Meridian Motorsport also sell throttle plates - probably best to get a price from them. The easy thing about throttle plates is that they are very compact.
Glenn sells 20V style throttle bodies in a range of sizes up to 52mm. Quite a good price considering what you get for them. Best to PM him or see what stuff he has for sale in the For Sale section.
Then there are a range of proprietary DCOE style throttle bodies that you buy as kits from Speed Technology or Injection Perfection. Both have websites - google is your friend.
