Results 16 to 18 of 18
Thread: best coil-overs for drifring86
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    Default Re: best coil-overs for drifring86
    if you really want captive springs, just use helper springs dammit!!
    or just shorten the coilover springs..
    i have 50mm shortened struts and when my apexi 7kg springs are *just captive, the car is at a decent low ride height anyways. but im still going to go lower..
    also, camber is what you want.
    AE86 - coming soon to a quiet mountain pass near you...
    WRX - currently epa'd...
    AE86 Pilot Grease Monkey skaney's Avatar
    Yes, 3 degrees neg camber. I went from 2.5 to 3 and that made an improvment. The understeer is cancelled out by a clutch pop most of the time, but having to balance the understeer/oversteer via the clutch doesnt leed to the smoothest drifting.
    try to balance the car though the suspension tuning. if you have adjustable braces, make the front a bit softer to get rid of that understeer (or the rear a bit harder). same with springs. or you could get some better or fatter rubber on the front (even if it's just the tyre size)
    edit: OR put some sigma LCA's in-the extra track and mucho camber will help greatly.
  1. checking timing on car with coil on plug setup
    Last Post: 23-02-2006, 06:52 PM
  2. Where to buy twin coil packs?
    Last Post: 17-12-2005, 05:17 AM
