Results 1 to 9 of 9
Thread: Clutch Pressure Plate Bolts - reusable? or not? (answer: not really for my applicatio
    Junior Member Grease Monkey twiztd's Avatar
    Aug 2006
    Default Clutch Pressure Plate Bolts - reusable? or not? (answer: not really for my applicatio
    Ok, so I have a stock 7mgte clutch bolted up to an R154 at the moment. I have a twin plate to go in but alas no new pressure plate bolts. So, will the stock ones (a) fit? (b) safe to reuse? The twin plate is an OS Giken TS2BD.
    Sorry to ask such a noob-ish question but I honestly can't find a concrete answer.
    Any help is appreciated.
    Mike
    Now - 1988 GX81 Mark II- 7MGTE, GT35R, TiAL 44m, Microtech, 550cc injectors, R154, Xtreme clutch, LSD.... Low boost tune done = 330rwhp@1 BAR...
    Then - 1989 MX83 - The big scrap heap in the sky...
    Toyota fanatic Grease Monkey Gttwinturbomk3's Avatar
    Jun 2007
    Dunedin
    Default Re: Clutch Pressure Plate Bolts - reusable? or not?
    What you will have to do is check the condition of the ones you have and if they look good not worn threads then they should be fine. As long as they do up properly then thats sweet as. You should torque them up to specs as well. What you will have to find out is when they are tightened up to specs what the diaphragm position is with your new twin plate in there.
    If the diaphragm ends are more than flush when you tighten the plate down then you will need spacers to accomadate for the extra thickness of your clutch disc. If the twin plate is the same thickness as the previous plate installed before with that same pressure plate than you wont need to worry about spacers.
    Aug 2006
    righto, so best to just try and pick up some new ones then aye?
    Ok, so, would anyone know where I can get some REAL quickly? (just incase I cant get them from otomoto)
    Mike
    Junior Member Grease Monkey progkamol's Avatar
    U can try Xspeed ... might be more in price but u'll get them quick
    Signed
    M4C
    Jun 2007
    Dunedin
    [QUOTE=twiztd]righto, so best to just try and pick up some new ones then aye?
    well yes, sounds like a fine idea
    Chiba
    ARP make them to suit your application. You need the 4AGE kit, part no. 203-2802
    Aug 2006
    if i recall correctly thats the flywheel bolt part number ya?
    i'm actually needing the pressure plate bolts. called grant at otomoto, none in stock atm, but i've figured out how to get my mitts on some.
    Thanks for the help guys!
    Mike
    Junior Member Automotive Encyclopaedia JZA70R_92's Avatar
    May 2008
    Default Re: Clutch Pressure Plate Bolts - reusable? or not? (answer: not really for my applicatio
    where did you find them?
    1992 - JZA70 STOCK - SOLD
    Chiba
    Quote Originally Posted by twiztd
    Mike
    Yea it is. My bad....
  1. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 05:17 PM
  2. hey all - need big help with flywheel -> pres. plate bolts
    By VeeP in forum Tech and Conversions
    Last Post: 16-10-2007, 05:57 PM
