Gavatron may be able to point you in the right direction, I think he had his made lumpy for the old rolla...
Just wandering if anyone has had their cam/s reground and if someone knows of a good place in Adelaide to get it done? Cheers
Noted, I'll ask him where he got it done unless he picked it up second hand. Cheers
There is one place that does regrinds but I'm not sure if any actually do hardfacing..... They are about the Wingfield area.
And in all honesty, the extra $30 in 2-way postage is offset by the number of profiles and technical help places like Tighe Cams will provide you with.
Places i was looking at include Tighe Cams (expensive), Clive Cams, Kelford Kams, Waggot Cams,
But i ended up buying from overseas.... (and it ended up costing more)
'77 RA28LT #2 ← 2.2L 18RG...
Got a message from Gav and he had his done at:
John Moyle Motor Engineering
1a Collins St, Enfield, SA 5085
abently, it's not the postage I'd be worried about with Tighe Cams but just the overall price. You do pay for what you get and I hear they make a quality cam but for what I'm going to be using it for it won't be worth me spending that much cash unfortunately.
Rad28, I found your other thread I believe and looked up all those names, really keen to go somewhere local in Adelaide if possible that's the only thing. Thanks
waggot camshafts - about $120-140 for a grind on a 4cyl twincam camshaft per cam
../delete/ban
tech moderator
So double it (for a SOHC) and add another $35 per 2 extra lobes and be looking in the $350 or less ball park?
PS, waggott double t right?
charge is per lobe @ $15-18odd per lobe (simple grind)
for full hardface weld and regrind (better option) its $40 per lobe
Waggott Cams
Address
Russelton Industrial Estate, 4 Hugh St
Alstonville
NSW, 2477
Australia
Contact Details
Ph:
(02) 6628 3795
call on tues or later in the week and ask to talk to peter - discuss what you want to do, and whats possible
../delete/ban
tech moderator
