yeah i think ill get new ones, anyone know where i can get HKS ones from? or can i just use Toyota ones?
Not recommended man, for the 8$ a bolt i'd replace them all! I have heard of it a couple times before, and would hate to have it happen to me or anyone i know directly...
That is the flywheel shears off the bolts and launches through the side of the box and up through the tunnel...
More likely to happen if you 'drive' the car and it sees revs a bit more then normal
Jase
Mazda Luce > Getting 1J love
Datsun 1600 big cam/port race L20B twin webers etc
"Yeeeees officer that shiney piping is factory"
You can get arp ones cheaper and better! I used factory toyota ones, and they were like 12$ each... I think arp are like 80$ for a set of 12..? Or something around that anyawy...?
Jase
ok ARP sounds like the go. Ill have to try to sus out where to get them from.
still looking around for a gearbox![]()
Heres a list of parts i need so far:
- R154 gearbox
- Clutch slave (if the gearbox doesnt come with one)
- Power steering pump
- main belt tensioner
- belt to suit 1jz minus air con
- flywheel bolts (if im not going to use the hks ones)
- tailshaft yoke for r154
- Front 1jz sump (have rear sump to swap if needed)
- JZA70 ECU
- gear shifter
- dump pipe and exhaust
- intercooler
oh dear lol
usually the engine is the cheapest part of a conversion
good luck son!
Project Soarer II - Sold
Evo 5 - The silver fruitbox
it would be soooooooooooooo much cheaper going auto. But i am going to press on with the manual.
box is a definate must soon though, as soon as i get the box the car,motor and box can go the the engineers so the mounts can be made up. then the rest will be all me.
ok so it looks like, by taking some measurements the 1J is going to be a tight fit length wise.
The gearbox however is going to have to be the longest one available i.e: from a JZX100 or JZZ30. If i get one of those boxes the shifter *should* come up in a near stock position.
yay.
got this bad boy from REVS today for a steal and it was in mint condition (came from an FD with about 30,000 on the clock). Installation was a easy as. The FD torsen centre fits straight in no worries at all.
All in all its an awsome diff now and well suited to the 929 i think.. If you just putting around then it pretty much stays open wheeler(ish), nail it and it locks nice and tight.. tight enough to easily hang it sideways for extended periods of time.
I reckon its also added a few km/h that i can do around corners as well.. the back end just wants to stick to the ground. LOVE it!
Also just bought these off of cressida1J. 18inch Rays Engineering rims (Gram Evo4?). The fronts are 8.5 inch and the rear is 9.5 inch, lots of rubber :lol:
ok guys, so i have been stupidly busy with uni and poor as well... buuuuut i though id chuck some progress pics upI am still collecting parts for the 1JZ conversion..
sounds good sim, well heres a couple of flix of my brothers car and my car down the beach the other day
