Results 1 to 9 of 9
Thread: Replacement V6 wanted
    70s Tragic Grease Monkey RA28tragic's Avatar
    Aug 2006
    Default Replacement V6 wanted
    Hi all. Just when things were looking up and up my wife did a timing chain in the V6, 3ltr, 4 Runner. I haven't put a spanner on it yet and don't want to untill I know what all of my options are. Does any1 know where I can source a low K V6. Or if there are any importers who could help me out with a low K import???? Rememeber I'm in RockVegas where V8 holden utes rule. It's hard to get support for Yummy Mummy 4 Runners.
    All advice most welcome. Sharp razor blades als welcome.
    Living in the 70s
    Default Re: Replacement V6 wanted
    What motor is it?? If its a late model V6, its probably a timing belt rather than chain. Also, if its a torquey low rev motor, its likely the valves arent interference type, so you could well have gotten away with it scott free... just replace the belt and be on your way. My ol 18RG dropped the chain once (bolt wiggled into timing gears), didnt do any damage other than the chain and sprockets.
    what model 4 runner and what model V6 - will be on the build plate (not the ADR/VIN plate) - i thought most of the toyota engine range were non-interference so loosing a belt is a PITA not a dead engine.
    wa
    v6 4 runners are not an interference engine
    just replace timing belt and you will be driving again
    about a 3 hr job
    belt is about 50 dollars
    As above, the 3VZ-E is not interference, but the 3.4L 5VZ-FE is.
    Aug 2006
    There is a god!!!!!!!!!
    Living in the 70s
    Supra since '86 Backyard Mechanic rsdeo's Avatar
    Burlington Ontario, Canada
    5VZ-FE is non-interference. Gates catalogue is wrong.
    Aug 2006
    Thanx for that. I was able to replace the timeimg belts and all is good.
    Living in the 70s
    Jul 2008
    i love happy endings
  1. replacement 1jz o2 sensor
    By audi2nr in forum Tech and Conversions
    Last Post: 19-04-2007, 07:01 PM
  2. Auto Replacement
    By Morguemaus in forum Tech and Conversions
    Last Post: 29-03-2007, 05:00 PM
