Results 1 to 2 of 2
Thread: Rotate a gt28r
    Junior Member 1st year Apprentice MarioM's Avatar
    Default Rotate a gt28r
    Hey all,
    need to call upon the collective wisdom of the toymods community. i need to rotate the front housing (not sure if thats the correct term) of my gt28r turbo maybe 90 degrees anti clockwise. the two questions i need to ask are
    - How do i go about rotating the front housing of the turbo
    - What happens with the wastegate actuator? Would i need to make up a custom bracket?
    Here are some pictures showing the problem
    thank you all in advance
    Mario
    Engineered and on the road - Just in need of a tune...
    Junior Member Backyard Mechanic gixer's Avatar
    Default Re: Rotate a gt28r
    It's called clocking, take off the bolts that hold on the wastegate actuator, then loosen the bolts which hold the compressor cover on, turn the compressor cover to where you want it, hopefully when the compressor cover is in the location you want it the bracket for the wastegate actuator will line up with some holes on the comp cover(or be very close to where you want it to be), otherwise you will have to drill holes in actuator bracket or make a new one.
  1. how to make two shafts rotate together... ???
    Last Post: 23-03-2006, 06:24 PM
