Don't go by hearsay if it's so easy to find out and be sure: grab a DMM and measure resistance of your current injectors!
You should be seeing about 2-4 ohms for low imp, over 10 ohms for high.
Hi I need some advice on injectors.
I'm running a single big t4 turbo and starvation is becoming a problem.
I have upgraded the pump to a walbro 250lph.
I have been told that the injectors are high imp by one person and low by another so im now confused (easy done).
Are they high or low and what am i looking for in replacements ( Prefarably cheap!)
Ijust need to find compatible larger cc replacements
A few link to review
http://www.toymods.net/forums/showth...ance+injectors
do a quick search and you will find lots of info
All your answers are here:
http://www.toymods.net/forums/showthread.php?t=23266
1971 2T-B Celica TA22 ST.
1975 2T-G Celica TA27 GT
1985 3F Auto FJ62 Landcruiser
Thanks thats a great great help abeit a lot of bs and arguing but i read the post and i get it that you found these:Originally Posted by TheToyman75
Nipondenso Part Number 23250 74160 as fitted to the N/A 3SGE - Generation 3 (SW20 MR2)
They are rated at 372cc @ 3bar and are 13.4 ohm so just under 20% bigger than the stock 1G injector so will work great with a signal bender like the Xede.
Now for a new stupid question.
????????? What's a signal bender ???????
(I'm feeling like on now this it a new learning curve why did i stick with a 1g?)
Leem,
A signal bender is a term used for a piggy back style or interceptor style ecu. I use and prefer the Xede over anything else n the market as it is capable of controlling fuel, ignition, boost and supports the addition of a Map sensor for greatly imporved mapping over the AFM signal.
My 1G runs like a dream and is fantastic on fuel now that it has the Xede. Not sure what sort of suport they have in the UK but there is bound to be something local.
