twisted eatons are halfway between a straightlobed roots, and a twinscrew.
actually, they are basically a twinscrew with no internal compression, or... a curved straight lobe.. whichever way you want to look at it.
original eatons had an outlet like this
http://s115271005.onlinehome.us/K24/MP198.jpg
just the V.
you can see the angle of rotors is same as the V.. that means that when new rotor air pocket opens to the V, air rushes back - heat = inefficiency
then you had next stage, where they have "cheater slots"
the cheater slots, or whatever you call them, allow manifold pressurised air to flow into the rotors cavity before it opens at the V, so that there is more pressure equalisation and higher efficiency
(the one on the left here has ben "ported".. ie the V is 1/4" wider and the ports smoothed)
from here http://www.matmoranmotorsports.com/about_car.html
this is an extreme example of porting and.. may not actualyl be good at all
basically, you want to reduce flow disruptors and have smooth ports.
as the rotora mesh together, they "squeeze" the air out, so increasing the actual size fo the V is not that beneficial..
changing the size of the cheater slots will change the rate of presure equalisation, and my own thoughts are that larger cheaters will be needed for higher rpm, to have higher efficiency, but at lower rpm, stock ones are ok... you wan tto reduce the yo-yoing of the air basically, between the cheater slots and the rotora cavity and the V..
inlet porting on the other hand, can be beneficial as the stock bits are often not great
but, you'd wanna be careful about opening the window, as you don7t want it to overlap with the V on the exhaust side...
if anything, i thin kit is better to allow more time for the intake (bigger window) and less time for exhaust (cos it will be squeezed out anyway)
but, take this with grain of salt
there is a lot of misinformation abotu SC porting, as it is a quick buck industry
