9. Cutting off the mounts from the MA46/MA47 housing.
10. The MA46/MA47 housing w/the mounts cut off. Welds ground flat, and laying in the jig getting ready to tack the AE86 mounts to it.
11. Fitting the mounts and tacking everything on.
12. Everything was good so it was time to weld.
13. Mmm, good beads. (no cleanup/slag removed in this pic. undoctored)
14. Housing is done, gave it a fresh coat of paint.
15. Housing mounted in the car, pretty much a perfect fit so far. Used the MA46/MA47 brake hard lines with some minor bending/rerouting at the ends to meet the AE86 backing plates. The AE86 center brake line threads & fits just fine. The Energy Suspension bushings fit perfect for mounting the swaybar (super snug).
16. 3rd member installed, you can see the steel braided brake line for the AE86 threaded into the diff side. Brakes are still capped off until I get the calipers on and get to bleed everything.
17. Axles & AE86 brake backing plates installed.
18. Installed my driveshaft, and exactly as I calculated based on housing/3rd members the driveshaft had be shortened 21mm or 13/16".
. That's ok tho, that motor took 3.5 years of absolute hell from me. Now I'm trying to line up a new powerplant but $$$ is low
