Results 1 to 13 of 13
Thread: bubbling noise from dashboard when taking off
    Nov 2007
    Default bubbling noise from dashboard when taking off
    When I start to accelerate from a takeoff I hear a bubbling noise from the dashboard which comes on for about 3 seconds then goes away. To be exact the noise comes near the radio unit and the ashtray.
    What could this be? Heater Core?
    Thanks.
    Aug 2006
    success 6164
    Default Re: bubbling noise from dashboard when taking off
    air in the cooling system/ heater core.
    http://www.ae82ownersclub.com/forum.php
    powered by 4agze ae82 goodness.
    7m? bhg time for you!
    RA23 - Twincharged
    JZZ20 - Daily
    Does the car cut out too when you drift it?
    blinker fluid... needs to be topped up
    edit: you also need to properly bleed your coolant system too
    Junior Member Backyard Mechanic VasH's Avatar
    Quote Originally Posted by Z2TT
    Thanks.
    mine used to do it when first started but after it was warmed up it was fine. its just water going through your heater core. Did u get your z20 back on the road?
    1989 JZZ20 Soarer, 1JZGTE - The Project
    1984 YN57 Hilux, 4Y - The Daily
    Quote Originally Posted by damo101
    Seconded. Had this in both the 7MGTE (until coolant was filled correctly) and in the 5ME (after getting my heater fixed) but now the 5ME is fine once I topped her up.
    Nov 2007
    Thanks guys.
    cuzzo yes it does, come over and fix it.
    oldcorolla's I cant find any blinker fluid, please send me some from japan as my blinkers are blinking very slowly and frowning at police cars, which will be a defect.
    kedderz nope I got a 1g, Head Gasket is fine.
    So the cooling system just needs to be flushed?
    Is there anyway of getting rid of the air pockets without flushing the cooling system?
    If flushing is the only option, is there any steps to take when refilling to avoid air pockets forming?
    Thanks all, Oldcorollas get onto sourcing me that fluid dude I'm going to get in trouble, i'm counting on you.
    cooling system needs to be BLED of air..
    that means, removing the air pockets.....
    either park on slope, or there will be a fitting at highest point of coolign system etc..
    should be in the manual for your car
    Tallahassee, FL USofA
    If you've been driving it over 3000rpm and the thermo. is working and the heater valve has been open and the heater system isn't clogged, the cooling system should be purging itself, so there is air getting into the system, from overheating or HG or leak.
    park on uphill slope.
    remove rad cap
    run car until it hits operating temp (ie: thermostat opens)
    watch bubbles come out
    profit
    if sound returns, you've got air getting in as allencr said.... then you cry.
    Quote Originally Posted by Draven
    remove rad cap
    profit
    Dont forget to also turn the heator on hot as well, especially if that is where the sound is coming from.
    Yeh make sure heater is on HOT, and bleed system properly!
    These days i top it up with a hose, and then stick a 2L bottle filled with water in the filler and just leave it until it starts to melt!
    CHeers,
    Jase
    JZA023
  1. Clunking / ticking suspension noise
    Last Post: 05-06-2008, 09:19 AM
  2. grinding noise from gearbox?
    By chaserbuddy in forum Tech and Conversions
    Last Post: 19-03-2008, 03:54 PM
  3. Info: Emissions and Noise Testing
    By infotechplus in forum Tech and Conversions
    Last Post: 09-04-2007, 12:33 PM
  4. Replies: 47
    Last Post: 16-01-2006, 06:08 PM
