That extra pin on the TPS is for the factory ecu, so it knows when the throttle is closed, so perhaps the resistance does change as it gets warmer, and thus affects its reading.
The idle end of the TPS is probably more important because the ecu is most likely programmed in MAP in the upper end, thus the TPS is just used for idle and tip in enrichment.
) : Wakefield 1:16.1 Racechrono
