Results 1 to 15 of 16
Thread: st162 celica with 3sge engine
    Oct 2008
    Default st162 celica with 3sge engine
    hi, i just brought this car, and it got the check engine light on, any ideas, does any one have a pin out for the ecu as well..
    Default Re: st186 celica with 3sge engine
    st186 didn't exist?
    Do you mean ST182?
    I am the sun
    Oct 2008
    yes that is what i mean
    the always broken 165 Carport Converter piggy's Avatar
    n.t
    is the check engine light always on? or does it come on after the car is running for a while?
    1974 TA22 Celica the new project
    2002 UZS171 Crown daily
    st165 white forged gen2 3sgte 264deg cams, 1000cc injectors, side facing plenum, GT30, CBR600 COP, 205 gbox, diff and calipers, haltech ecu,coilovers, 3'' exhaust, water meth injection 235AWKW @ 22psi 12.29@117MPH 1.885 60'
    Oct 2008
    yeah it all was on.. it might be the 02 sensor not connected.. but i cant find where it goes.
    when i start it, it idle really high at 2000rpm for a while then drops is that normal?
    n.t
    when my o2 sensor was playing up in my 162 the check engine light use to come on.
    jack up the car and follow the exhaust system on a 162 it was near the firewall. have a look there mate
    n.t
    hope these help here is a pin out and a few other things for a gen2 3sge
    http://www.fixya.com/cars/t931513-electrical_diagram
    Oct 2008
    i know were the o2 senosr is, it is on the manifold behind the radiator.. but i can find were it plugs into
    Oct 2008
    thanks for pin out
    Oct 2008
    i need a lot of parts for this car, do you know of like a online parts book or something so i can find them? and then order it.. cheers.
    n.t
    what parts are you after? and is it a 182 or a 162 you have?
    Oct 2008
    it is a 162.
    i need all the metal window surrounds, for both left and right rear windows, i also need them for the boot lid, and the window seal for drivers door. i need both door trims. air box mount brackets, o2 sensor. and centre console. all air vents in dash
    and that for starters
    n.t
    well since thats the case that pinout is incorrect
    here is the correct pinout
    http://www.geocities.com/MotorCity/P...Pins_3S-GE.gif
    have you considered going to a wreckers to get the parts that you are after? there are plenty of 162's in them these days
    Oct 2008
    tried local wreckers , not worth pissing on.
    n.t
    Default Re: st162 celica with 3sge engine
    fair enough o2 sensors you can get from your local repco supercheap etc etc there not too expensive
  1. MA70 --> JZA70 Conversion
  2. Celica Ra65 engine swap to 7mge
    By Mk3_supra in forum Tech and Conversions
    Last Post: 18-08-2007, 09:06 PM
  3. Turbos 101
    Last Post: 24-01-2007, 07:23 PM
