Let me get this straight,
The ring on the bearing retainer from the corona is actually larger in diameter than the outside diameter of the TA22 bearing. Are you talking about the early D-Series (read poo poo) or the later T-Series (read pooish) diff?? If you want to put the corona bearings on, you will then run into the trouble of the outer diameter of the bearing being too large, and not fitting into the housing.
If you mean the bearing isnt wide enough and will float side to side, measure the width required, the inner diameter and outer diameter, and contact every bearing shop in town to try and find the required bearing. This will solve your problem... and all you need is those three widths.
Alternatively, modify the retainer ring so that its going to be the correct size with respect to the bearing.
