you might want to look into doing the hilux/peugot/xt130 swap. and i expect that using these struts will give you neg camber whic is never a bad thing. you may have to use the associated steering arms with it though
I would like to have some beefy brake hardware out front. I know that RA65 stuff bolts up, but I want something better, chunkier. What could I use to grind me to a halt quick smart?
AE93 SX - Thrasher 20V
JZX100 Chaser - Daily 1J lovin
hello
If you really wanted big brakes I can't see why a Nissan 4 piston setup of say a Z32 with 280x30mm discs couldn't be adapted.
If in doubt power out
MA61 hubs and brakes are a direct fit on RT142 struts, so by extension any of the brake upgrades developed for the MA61 (and there are quite a few of them now) will work on an RT142.
Norbie!
www.norbie.net
...assuming the caliper mount is suitably located to clear the suspension/steering components.
The caliper mount doesn't need to be changed so this isn't an issue.
Norbie!
www.norbie.net
Far out! No problems stopping now.
Don't know about that norbs....Originally Posted by Norbie
Charles and I have had a look at a set of RT142 struts and the calliper bolt spacing was not the same as xA6x, so it wouldn't fit the Z32/R3x stuff either!...
There is a thread where thechuckster has a pic showing the camber differences between an RT142 strut and a MA61 one, and he also mentions the difference....
Well I've personally witnessed A6 brakes bolting up to ST141 struts with zero mods required. Perhaps RT142 struts are different then?
Norbie!
www.norbie.net
RT142 struts are different to ST141s and also to XT130s. They all have slightly different spacings.
The XT130 is 90 or 95mm btw.
Woah, how wierd is it that RT142 front struts are different to RA65, when the rear IRS is the same!
Because, the RT142 didn't all come with IRS, um like mine hence its rear suspension steup isn't always the same
Could be an early/late model thing. Did they do any re-releases of the Corona in that time?
OK then, it's safe to say that some versions of the xT14x Corona have struts compatible with xA6x Celica/Supra's, WRT hubs and brakes. Just guessing here, but methinks it would be a straightforward matter to swap struts between different versions of the xT14x Corona to facilitate an easy brake upgrade.
Norbie!
www.norbie.net
