Results 1 to 15 of 20
Thread: A430 Auto - Manualised
    Act
    Default A430 Auto - Manualised
    Hi guys first of I don't know a heap about auto's hence the questions
    I pulled a A430 out of MS112 from behind a 5ME.
    Now I want to manualise the auto, behind my 7MGTE without factory ecu.
    I found that the auto I pulled out only had a Over drive switch wired to it, there was no A/T ecu only an EFI.
    So what I want to know is if I send this box a way to get the valve body modified by say C&V or who eva they are in adeliade. To shift kit it, do I need on of their ECU's to make it shift or is this box hydralic controlled so I only need a over drive switch.
    thanks guys
    Default Re: A430 Auto - Manualised
    I would have thought it would have an A43D?
    In that case it should be fully hydraulic, just with the OD switch for 4th. (No control box)
    Pretty sure that was the case with my 5ME auto in my MX62
    PS why the want to use that box, and not an A340E?
    Wilbo's JZA80
    Wilbo's JZZ12
    A340 is easy, there are a few people selling shift boxes for them
    I have one in the bunky and i wired up a switch for the torque convertor lockup too
    Act
    I would have thought it would have an A43DE?
    Whats the difference??
    I thought they were all pretty much the same
    Sciflyer ill look for some links
    The A43DE is very similar to the A340E, ie 3 solenoids, full electronic control.
    But the A43D will be a completely hydraulic box with the only electronics behind overdrive, and *possibly* lockup torque convertor (if its an A43DL).
    I doubt its an A43DE, so its either an A43D or A43DL.
    Either way a) it will work fine without an ecu and b) it won't last more than a week behind a 7MGTE.
    Act
    so really im after a A340E then, which I can take it are from later model stuff
    I'll start really searching
    please tell I can atleast use the bell housing
    I know my old A43DE had an integrated bellhousing, so I'll presume the A43D is the same, and thus no, you cannot use the bellhousing.
    Act
    damm its all getting all bad then
    Pee wee can I rack your brain a bit more is there a direct replacement tail shaft and lengh wise auto that I can swap out for an auto??
    or no matter what way I go im looking at tail shaft mods
    Act
    No matter what, you'll be looking at tailshaft mods.
    That will work, but I'm not sure how long an old 7MGE autobox will hold up behind a boosted 7MGTE.
    Forum Sponsor Conversion King
    Stitty,
    ive got a box and flexplate here if you need them but ill have to find a converter for you.
    Give me a buzz tonight if you need some info.
    I can get the shifter setup in my ute copied if needed
    Linden
    Aug 2006
    Stitty, im pretty sure i got a converter and flex off a 7mge if you want, need it. Have a a342 of a jza70 too....
    vic
    Also the A43 D is longer than a A340 which makes it harder to use in most conversions. Alltho the output spline is the same as a W58, you still would need to shorten the tailshaft to use the A43 .
    Dave
    Act
    thanks for the info boys
    pm sent linden
    just saw this thread
    stitty my mate has 2 MX83 boxes with converters and flexplates he isnt using wants to offload them for mega cheap
    let me know and ill hook u up
  1. w50 to auto?
    By dundee230966 in forum Tech and Conversions
    Last Post: 30-06-2007, 08:01 PM
  2. Auto build shopping list
    Last Post: 25-01-2007, 08:40 AM
  3. GZ20 auto to maunal conversion
    By Big rob in forum Tech and Conversions
    Last Post: 03-03-2006, 07:15 PM
