I've never done it to a MS112 diff but I'd assume it's a fairly generic process.
- Pull the drum off
- Pull the axle retaining plate off by sticking a socket through the hole in the end of the axle to undo the 4 nuts, obviously rotate the axle to get to each
- Use an axle puller to pop the axle out
Installing is revers of the above. In this situation where the axle is bent I really recomend making sure you have a good axle puller to use, I can see the old reversed drum being used as a slide hammer taking a long time on a munted axle.
