Results 1 to 15 of 29
Thread: HELP: 1GGTE running slow, Error code 11.. what is it? *FIXED*
    Don't Trust Me I'm A Backyard Mechanic Jabtronic's Avatar
    Gold Coast, QLD
    Default HELP: 1GGTE running slow, Error code 11.. what is it? *FIXED*
    My 1G Soarer just started acting up tonight, it's idling ok (maybe 100rpm higher than usual), but it's extremely low on power and backfiring a lot. My boost gauge isn't indicating any boost leaks because it's still boosting fine up to 1bar. There's just no torque though and the engine is running slightly louder than usual, I could barely make it up my driveway
    I checked the error codes and it brought up code 11 but I can't find 1GGTE error codes anywhere, can somebody link me please?
    Gotta rush off to work now so I won't be able to take a better look at it until tomorrow. I'm thinking it's either the dizzy, sparkplugs/leads or AFM? I cleaned the ISCV 2 months ago.
    Before it started playing up, it stalled on me once or twice during the week. And also the idle always fluctuates/misses a bit (however it isn't now.. it's idling maybe 100rpm higher than usual and is constant)
    Any help would be appreciated cheers.
    EDIT: I found that my distributor was loose! So the timing would have been way out...I've put it back to +10DTDC and it still runs slow Need more ideas
    FINAL EDIT: It's been fixed! An autoelectrician found a short in the AFM wiring, which was overheating the ECU.
    Gold Coast, QLD
    Default Re: 1GGTE Error code 11.. what is it?
    Ok now the car isn't starting, it starts slowly after cranking for 5 or more seconds and then comes to life but stalls shortly after. I can smell excess fuel so fuel pump doesn't seem to be the problem.
    EDIT: Got it started, it started and was chugging along poorly (like it was on 5cyl) with a clicking noise coming from around the ISCV area (but not the ISCV.. maybe a spark plug lead??) and when I gave it a touch of revs it went back to a normal-ish idle.
    Junior Member Grease Monkey Brad-KE35's Avatar
    Could it be the alternator? Maybe its on the way out and isn't powering the ECU properly, which would mean low voltage and possibly causing it too backfire and miss weirdly.
    Just my 2c.
    Brad
    1977 Toyota Corolla KE35 - Undergoing 4AGTE transplant.
    1994 Ford Falcon Pedovan - Rape Dungeon
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    Code System Diagnosis Trouble Area
    1 Normal There are no problems. None.
    2 Pressure sensor signal Open or short circuit in pressure sensor. Pressure sensor circuit.
    Pressure sensor.
    ECU.
    3 Ignition signal. No signal from ignitor four times in succession. Ignition circuit (IGf ECU connection).
    Igniter.
    ECU.
    4 Water thermo sensor signal Open or short circuit in coolant temperature sensor signal. Coolant temperature sensor circuit.
    Coolant temperature sensor.
    ECU.
    5 There is no code 5 (this sounds like the Monty Python "Bruces" sketch!).
    6 RPM signal. No Ne, G signal (engine revolution sensor) signal to ECU within several seconds after engine is cranked. No Ne, G signal (engine revolution sensor) signal to ECU within several seconds after engine reaches 1,000rpm. Distributor circuit.
    Distributor.
    Starter signal circuit.
    ECU.
    7 Throttle position sensor signal. Open or short circuit in throttle position sensor signal circuit. Throttle position sensor circuit.
    Throttle position sensor.
    ECU.
    8 Intake air thermo sensor signal Open or short circuit in intake air temperature sensor signal. Air thermo sensor circuit.
    Air thermo sensor.
    ECU.
    9 Vehicle speed sensor signal Speed sensor indicates 0 km/h for several seconds when engine rpm is above 2,300 or 2,800 and manifold pressure is higher than specified. Vehicle speed sensor circuit.
    Vehicle speed sensor.
    ECU.
    10 Starter signal. No STA signal to ECU when engine is running over 800rpm. Main relay circuit.
    IG switch circuit (starter).
    IG switch.
    ECU.
    The vehicle has been push-started.
    11 Switch signal. Air conditioning switch on or IDL points in the throttle position sensor off. Not registered in memory. Air conditioning switch circuit.
    Air conditioning switch.
    ECU.
    12 RPM Signal No G or NE signal present for 2 seconds during cranking
    Open G circuit
    Open, short in G or NE circuit.
    Distributor
    ECU
    13 RPM signal No NE signal for 50msec at 1000rpm.
    Same as Above
    14 Ignition No IGF signal to ECU for 4 consecutive IGT signal during engine running
    Open/short in IGF/IGT signal from igniter to ECU
    Igniter malfunction
    ECU
    21 O2 sensor Open/short in heater circuit of oxygen sensor for 0.5 seconds
    Amplitude of O2 sensor reduced to 0.35-0.70V continuously for more than 60 seconds
    O2 sensor
    vacuum sensor
    ECU
    22 H2O temperature sensor no signal at THW
    water temperature sensor
    ECU
    24 Intake Air Temp sensor no signal at THA
    Intake air temp sensor
    ECU
    25 A/F Lean O2 sensor output in less than 0.45 volts for at least 90 seconds when O2 sensor is warmed and 1500 rpm or above.
    open injector circuit
    lack of fuel pressure
    Ignition system
    Vacuum sensor
    O2 sensor
    ECU
    31 Vacuum sensor No signal at Vacuum sensor (PIM)
    Vacuum sensor to ECU
    33 ISCV (Idle speed control valve) Open or short in ISCV circuit
    ISCV Valve
    41 Throttle Position sensor No signal for 0.5 seconds or more at ignition ON. (VTA)
    TPS
    ECU
    42 Vehicle Speed Sensor No speed sensor signal to ECU when loaded driving condition with engine speeds 2000 to 5000 rpm. for 8 seconds or more.
    VSS
    ECU
    43 Starter No starter signal to ECU when cranking in TEST mode. Terminal STA on ECU
    starter signal circuit
    starter relay
    ignition switch
    52 #1 Knock sensor no KNK1 signal to ECU
    knock sensor (looseness)
    malfunctioning knk sensor
    53 #2 Knock sensor no KNK2 signal to ECU
    same as above
    51 Switch condition signal Displayed when A/C is on when TE1 and E1 connected in test mode
    A/C switch
    Accelerator pedal, cable
    ECU
    Gold Coast, QLD
    Quote Originally Posted by Brad-KE35
    Just my 2c.
    Brad
    That's a good point, my 1JZ had similar symptoms when the alternator died, will check it out tomorrow.
    And thanks ta23-mbzq-nnr for the codes. Looks like it could be an error 2, stuffed AFM?
    +rep
    Nov 2007
    Check your ignition coil too.
    Gold Coast, QLD
    Well I rounded up a few spare parts over the weekend to test out.. finally got around to having a look at the engine today and think I've found the problem already, I can rotate the distributor easily by hand, so the timing is probably way out and has been playing up because it can probably move by itself, the bolt must've come loose.
    I've never adjusted the timing before so I'll have to go and buy a timing light and fix it up and see how it goes.
    Gold Coast, QLD
    Lined the timing up to roughly +10 degrees, bit hard to be exact though because the white mark is about a cm long?
    Only checked the AFM and spark plug leads so far with some spares I borrowed. And it's still running like shit, it idles fine (*usually... won't start sometimes though unless I leave it?, and once or twice have started it up and it ran like it was on 5 cyclinders) it basically has lost power all throughout.. I'm hoping that the timing being out didn't fuck the engine. I'll be replacing spark plugs tomorrow and will check compression also.
    Should I replace the fuel filter? Anybody reckon the injectors could be leaking or something?
    Junior Member Backyard Mechanic VasH's Avatar
    Quote Originally Posted by Jabtronic
    weird, you do say a while back it overheated not loosing any coolant at all? you check all the plugs make sure none of them where fouled? check your knock sensor under the plenum are plugged in. Fuel filter is a bitch to get too its above the diff.
    Have you tried taking it off the battery for a while too reset the ecu and see if it comes up the same error code?
    Check under your dizzy cap aswell.
    Sounds like its gonna be a process of elimination with this one.
    1989 JZZ20 Soarer, 1JZGTE - The Project
    1984 YN57 Hilux, 4Y - The Daily
    Gold Coast, QLD
    Default Re: HELP: 1GGTE running slow, Error code 11.. what is it?
    Yeah it was overheating that day I drove up to Brisbane only on the highway, it's never done that before (or since) and around town has always been fine. There were no signs of BHG either but I havn't looked at the coolant since. (Dipstick oil looks fine) Will check it tomorrow arvo too.
    The timing could have been out for god knows how long, I noticed sometimes it was a bit wierd starting the car.. so I guess there's a good chance engine is stuffed due to detonation or something?
    I've reset the ECU, no difference except it idles higher obviously until it's sorted itself out again.
    Annd I cleaned out the plugs today, forgot to mention that sorry.. the 4th plug was covered in oil , well I guess that's definitely telling me something (my cam cover seals are leaking a little, but on this plug the tip was covered in oil), the others looked a little dry with only slight whiteness on the tips?
    Will have to see the results of the compression test before trying anything else I suppose.
    that could be your problem might be stem seals leaking on #4 and killing spark. Give the plug a good clean and earth it on your motor somewhere and check if its sparking still.
    Gold Coast, QLD
    Ok well I checked the compression, pretty much 140psi across all cylinders.
    I went to change the spark plugs but SuperCrap didn't have any BCPR6EP-N-8 (or any BCPR6 plugs), so I got BPR6ES ones thinking they'd fit fine but they don't because the plug galleries on the 1G are too small for the bigger socket thing to fit down.
    Sigh, so I'll try a few other places tomorrow for the proper plugs.
    Also when I pulled spark plug 4 out again, there was no oil on it so I guess that was oil that had leaked from the cam cover seals.
    Carbon neutral Carport Converter Jt_70R's Avatar
    Could also perhaps be stuffed ecu a-la 1JZ style? no idea if the 1Gs suffer the same prob, but a quick swap could be worth a check.
    Gold Coast, QLD
    Yeah I was thinking that also. Hopefully the ignition timing was just wrong and fouled the plugs or something, we'll see tomorrow.
    Gold Coast, QLD
    Quick update.
    Tried new plugs on Friday (hadn't started the car since Wednesday)... it started up fine, idled up to running temp fine, so I took it for a drive around the block... was still down on power. I pulled up after 2 min of driving, (was speaking to someone) and the car started stalling and then died and wouldnt start.
    I reset the ECU and tried again and it started up eventually. Then I tried to drive back home and the revs started going up and down and the engine would stall unless I kept the revs up. It was struggling real bad under load and backfiring, it ended up coming to a stall again (down the road from my house) and wouldn't start so I had to tow it back to my driveway.
    It's gotta be an electrical problem? Doesn't seem to be fuel blockage because it was revving up and down.
    Sigh.. looks like I'm going to have to inspect/replace the ECU
  1. RA28 with 1GGTE, need some advice of the o so wise ones!
    By MIN728 in forum Engine & Driveline Conversions
    Last Post: 14-05-2008, 06:08 AM
  2. 1ggte AFM
    By GhostWalker in forum Tech and Conversions
    Last Post: 22-02-2008, 09:02 PM
  3. RA65 22RE Bellhousing vs 1GGTE
    Last Post: 18-08-2006, 04:58 PM
  4. 1GGZE SC on a 1GGTE?
    Last Post: 22-06-2006, 07:15 PM
