Results 1 to 7 of 7
Thread: 2TG into RT40 Corona
    Nov 2008
    Default 2TG into RT40 Corona
    Hi, has anyone got any tips or info on fitting a 2TG motor into an RT40 corona? ie mounts, sump etc...
    Daniel
    Junior Member Domestic Engineer tricky's Avatar
    Default Re: 2TG into RT40 Corona
    I'd hazard a guess that an 18RG would be a hell of a lot easier, to be honest. I'd say at the very least the mounts would be custom. You'd probably be able to get a sump to clear without too many issues.
    Nikita the RA23 is almost finished .
    Junior Member Grease Monkey MAD79R's Avatar
    OSJ from these forums had an RT40 with an 18rg a long time ago might try getting advice from him
    (\__/)
    (")_(") ITS ALIVE
    Tasmania
    I also did a 18RG conversion into the old shovelnose Rona all went fairly easy.
    Cheers Brett.
    RT40's have a mid sump. so to fit a 2TG you need to drastically modify the cross member. I've got a front cross member modified to accept a 4A-GE, but it's in my RT40, which is in Broken Hill. and I'm now living in QLD. so I can't even take pics of what needs to be done for you.
    18R-G would be much easier as they have a mid sump, or other mid sumpe motors eg: L18.
    Jordan
    Is a Self Employed Grease Monkey wombat's Avatar
    try the guys at www.coronacountry.com as well. I'm sure I've seen it done on there as well. definately a 18rg not so sure about 2tg though
    I am currently doing a 4AGE install. Check out my thread or fire any questions you may have about anything or if you decide to go with a 4age. Should be able to crank mine over and start it come xmas. *fingers crossed*
  1. RT40 Shovelnose Corona ........ 4A-GTE?
    By AE92 Rolla 4A-GTE in forum Tech and Conversions
    Last Post: 14-08-2007, 04:50 PM
  2. RT40 Corona Questions
    By dj1979 in forum Tech and Conversions
    Last Post: 25-03-2007, 09:43 AM
  3. 20v in RT40 69 corona
    By 20valve69corona in forum Tech and Conversions
    Last Post: 28-08-2006, 10:52 AM
