Results 1 to 9 of 9
Thread: SOLVED hopefully. Fuel system not working.. wierd problem
    Question SOLVED hopefully. Fuel system not working.. wierd problem
    Wierd problem with my fuel system - when I try to adjust the pressure - anything above 20psi and the pressure regulator starts oscillating - pressure fluctuates between 20 - 60 psi on the gauge and the fuel lines can be heard rattling.
    Anything <= 20psi is fine.
    Fuel setup:
    Surge tank
    8-9mm feed and return lines
    Bosch 044 external pump - capable of up to 72.5psi apparantly
    Standard gen2 3sgte fuel rail
    Fuel fed to both ends of rail - return in middle as in pic
    Sard rising rate feul pressure regulator - adjustable up to 100psi apparantly
    Any ideas anyone? I'm lost
    Default Re: Fuel system not working.. wierd problem
    Can you please identify each inlet/oulet of the surge?
    See attached
    Try putting the lifter pump line on the bottom feed. It's a guess, but the potential foaming effect from the fuel falling that far could be causing the main pump to be drawing in airated fuel that can cause cavitation and fuel line hammering.
    So you have two feeds from the surge to the motor?
    No...
    One feed from the surge to motor
    Quote Originally Posted by d-shiznit
    No...
    Sorry misread, got it!
    Is the FPR hooked up correctly (I assume it is, just random question).
    Have you checked the voltage at the pump at different pressures?
    OHMYGOD I'm an idiot.
    The instructions were japanese so I threw them out.
    After searching around I realise that yes - I hooked the lines up the wrong way
    Hope it hasn't damaged it.
    Should be return into the side, outlet at bottom....
    I stupidly assumed the other way around.
    Thankyou for asking the obvious question CrUZida.
  1. 1JZ ignition or fuel problem??? Plz Help
    By gztwenty in forum Tech and Conversions
    Last Post: 04-07-2010, 08:02 AM
  2. JZA70 wont start...problem is very very wierd
    Last Post: 19-11-2008, 03:42 PM
  3. 1ggte fuel system mods
    By MOOKIE in forum Tech and Conversions
    Last Post: 02-01-2006, 11:15 PM
  4. EFI fuel system
    Last Post: 15-12-2005, 04:39 PM
  5. Replies: 1
