can be purchased aftermarket from almost any bearing supplier but i have no idea what the P/Ns are. if you measure them up most bearing shops could tell you within about 2 mins.
Does anyone have a part number for F-series (IRS xA6x) pinion bearings? Are these able to be matched aftermarket, or need to be bought from Toyota?
Thanks![]()
Originally Posted by WHITCHY
OK, thanksAny idea roughly what I should expect to pay?
depends on the store but between $35-45ea but i wouldn't expect much more than that.
most places should have them in stock but that also depends on the area you live in.
i have only just gone through this myself,
30306CA X1
32307C X1
M1067 X1
R41Z17 X2
M1065 X2
These are all CBC numbers and at a rough guess you should be looking at about $240.
I got the full kit but this is a start for you.
Thanks for that - two are side bearings which I already have new (with TruTrack), some of those are pinion - what are all the others?
BTW do you have a GA65, or are you currently building one? We should probably have a chat![]()
the M1067 would be the diff pinion and M1065 the two side seals.
30306CA and 32307C would be 4 the pinion shaft. that is my guess.
I have a RA65 with a 1GGTE in it. SO not technicly a GA65 but as good as. my car is finished but i keep tinkering with it.
RA65 + 1G = GA65.There was never such a thing as a GA65 from the factory.
