Results 1 to 4 of 4
Thread: 4afc mis on mod-hard accel
    Default 4afc mis on mod-hard accel
    Hey,
    I have a 4afc in a nova and it has a bad intermittent misfire when i give it moderate or hard acceleration. i have recently changed the plugs to correct a misfire which has worked but under load the engine still sounds like a tractor. any help??
    Jun 2006
    Default Re: 4afc mis on mod-hard accel
    maybe it is running lean, any vacuum leaks?
    wa
    check the leads
    usually can cause a misfire under load
    Insert whitty comment her Automotive Encyclopaedia blacktop's Avatar
    Aug 2006
    as 2jzhilux said check leads, dizzy cap, rotor, points, you could probably replace the whole lot for less than $80 and 30 minutes work.
    if none of that fixes the problem check the timing.
  1. 4agze hard to start and then stalls
    By wiso in forum Tech and Conversions
    Last Post: 07-12-2006, 11:31 PM
  2. 3SGTE Hard to start
    Last Post: 27-01-2006, 11:16 AM
