The HDI GT spec Tube and Fin intercooler setup for the JZA80 Twin Turbo suited pretty well. The bottom mounting plated didn't fit so needed to longer aliminium mounts, also Some of the hard lines in front of the radiator needed moving, just by undoing there mounts and moving the piping along a little, other wise it was installed as the instructions except for the pipe that goes to the turbo inlet. The first two Black JZX100 intercooler piping bits were kept as pictured, they don't mount up with the JZA80 piping but the end of the pipe left over JZA80 piping kit can be cut off the and used to join up to the factory piping, it fit well and keeps more of a factory appearance in the engine bay at least on the turbo side.
I was pretty happy when the car started first go, took it easy for the first couple of weeks to make sure everything was ok. Had a bit of a minor leak in the power steering, so I am going to rebuild one of my power steering pumps and flush the system with new fluid. Overall very happy with the performance very responsive engine, is running a stable 10.6 PSI, as it is have the HDI boost controller but not tried running more boost just yet. Feels to have plenty of power as it is at the moment, hope to get it on a dyno in the near future just to get an idea of what it is putting out.
