Results 1 to 2 of 2
Thread: Installing sard injectors - 3sgte gen2
    Question Installing sard injectors - 3sgte gen2
    Hey everyone,
    I'm trying to swap my stock gen2 3sgte fuel injectors with Sard 850cc ones.
    The Sard injectors come with collars, and are SUPPOSED to be a direct swap - but I'm finding that they aren't...
    THE GOOD:
    The supplied collars fit perfectly and positioned the injectors at the correct level for fuel to enter.
    THE BAD:
    Firstly the supplied upper O ring is too big to fit into the fuel rail - I overcame this problem by using the stock upper O ring - seems to seal fine.
    Secondly, the injectors are not sealing at the bottom - by a lot - fuel pisses out.
    The Sard injectors have a smaller lower diameter than the stock ones, which can be seen in the attached pic (top is stock, bottom is sard)... also in the pic is the sard supplied lower O ring next to the stock O ring - again showing the lower diameter difference.
    Anyone had experience with this? Any ideas?
    Are there such things as 'lower' adapters that I could be missing?
    Thanks,
    Jeremy
    Default Re: Installing sard injectors - 3sgte gen2
    After hours of trying different O ring combos, spraying fuel all over the shed and searching the net, problem solved!
    The shop sent the wrong collars - I found this out by finding a picture of the correct 3sgte adapter collars.
    What is amazing is how clueless the shop is, telling me I didn't even need the collars, to just 'bolt straight on, then ok'.
    All these incompetent people *sigh* I didn't think changing injectors was so hard.
    Moral of the story?
    Changing injectors is easy. Just make sure the shop sends you the right parts.
  1. 3SGTE Injectors.
    By off-road in forum Tech and Conversions
    Last Post: 07-08-2008, 09:10 PM
  2. Fitting 540cc injectors to Gen2 3sgte
    By EVL-184 in forum Tech and Conversions
    Last Post: 24-08-2007, 11:58 AM
  3. JZA80 Apexi PowerFC with Sard 1000cc injectors problem, HELP!
    By Sicarius123 in forum Tech and Conversions
    Last Post: 22-05-2007, 08:22 AM
  4. Aftermarket engine management and injectors
    Last Post: 14-05-2006, 01:05 PM
