Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: 3tgteu cam sync sensor for progamable ECU?
    Texas,USA
    Default 3tgteu cam sync sensor for progamable ECU?
    Does anyone have any input on how I can go about adapting a cam sync sensor to a 3tgteu. I can't use the stock dizzy because I am using cams with no dizzy drive.
    ae-86 (levin) footwork
    TE-71 w/1uzfe
    Autronics SM4
    New Zealand
    Default Re: 3tgteu cam sync sensor for progamable ECU?
    From very rough memory, I believe someone here used the standard non twin cam dizzy drive. As the cam is still in the block to drive the oil pump it should be do-able.
    Callum
    Texas,USA
    Did they use the twin plug turbo head? With that head there is not enough clearance to remove the oil pump drive and install a dizzy because of the extra metal from where the twin plug dizzy goes on the head. Maybe they clearanced around it?
    TE-71 w/1uzfe
    Autronics SM4
    I have a haltech e6x, and used a haltech hall effect setup on my 3T-GTE. This was done using the existing dizzy and making a trigger disc with 4 rare earth magnets as pickups.
    Because you won't be using the dizzy, I would think you could mount a similar trigger disc as mine to the front Pulley?
    See my 3T-GTE powered TA22:
    Click Here
    Currently running 192.8rwkw @ 20PSI
    Texas,USA
    I already have a crank position sensor. I need #1 tdc reference.
    TE-71 w/1uzfe
    Autronics SM4
    New Zealand
    I can't seem to find the details but I think it was a very cut down dizzy, head may have been clearanced.
    Callum
    Texas,USA
    I think that may be my best option. Do you remember what T series engine came with the short dizzy. I think all the 3tc motors came with the tall dizzy.
    Man I sure hope I can do it without pulling the head.
    P.S. that is not a pic of my engine. Just a generic pic.
    TE-71 w/1uzfe
    Autronics SM4
    New Zealand
    You should be able to cut something down to suit if its just for the cam sensor, depends if you have access to any machining equipment to make something up.
    Callum
    Remake the crank disc with a missing tooth.
    Then program the ecu to see that missing tooth to know where TDC is.
    Many engines use this.
    Texas,USA
    Yes but that only references TDC not TDC#1!! I already have a TDC crank sensor set up using two magnets and a hall effect sensor.
    TE-71 w/1uzfe
    Autronics SM4
    I gather you aren't running wasted spark then ?
    Texas,USA
    I am running wasted spark!
    TE-71 w/1uzfe
    Autronics SM4
    Well with wasted spark it doesn't matter if you are TDC#1 or TDC#4 (assuming you are also running 2 groups of 2 injectors).
    Correct me if I'm wrong here.
    Texas,USA
    That is correct. However I am not concerned with wasted spark I have that working well. I want sequential injection That is why I need a home/cam sync.
    TE-71 w/1uzfe
    Autronics SM4
    Junior Member Domestic Engineer Hurricane's Avatar
    i know datto boys use ca18 sencors and mod them to fit inside the dizzys, the only ways ive heard are to use a dizzy and make a sensor inside.
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
  1. Toyota BEANs, Multiplex etc
    Last Post: 14-12-2016, 06:21 AM
  2. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 07:10 AM
  3. Toyota diganostic error code, where can i find them?
    By MarkIIRx12 in forum Tech and Conversions
    Last Post: 19-03-2008, 12:42 PM
  4. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 06:31 AM
  5. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 10:17 AM
