Are you talking about 8mm between the end of the bellmouths and the vertical wall of the airbox ?
If so, that's not much at all. If not, then the vertical height above and below the trumpets is probably not that important, but there seems to be a variety of numbers that help govern the size of a plenum, and for high revving engines, it typically appears to be about 2.0 to 3.0 times the engine capacity.
Make sure that none of the air comes from under the bonnet. It amazes me the number of cars (and a lot of workshop high powered ones at that) that take air from directly behind/near the radiator.![]()
I think you know that already though !!
