Results 16 to 25 of 25
Thread: Help me figure out my clutch problems [More problems!]
    Default Re: Help me figure out my clutch problems [More problems!]
    haha sorry yes he did. I already repped him for it but have to spread the love for you
    but yeah norbie said there was a whole dellows conversion kit for 1jz -> w58 which i didnt know about. Didn't realise Pure insanity mite be talkin bout that, thought he just meant the flywheel only was custom. But yeah now i know just gettin a jza80 flywheel wont work cos of the bellhousing and clutch fork being dellow's.
    Thanks heaps guys! Much appreciated.
    1977 RA23 Celica -> 1ggte conversion [SOLD]
    MA70 Supra 1JZ 5speed [SOLD]
    Current: IS200 1JZ VVTI 6 speed
    Quote Originally Posted by Pure_In_Sanity
    If the flywheel bolts are definately imperial it's not toyota.
    Maybe a dellow or crs? Does it run a holden pp?
    ARP bolts are not metric....
    Quote Originally Posted by Hash_ra23
    Wrong
    You can use a JZA80 2jzge flywheel with dellow bellhousing and fork.
    I've done it.
    oh true!
    Is there any advantage to this besides being able to use a supra clutch kit instead of a holden one? I'm thinking i'll just stick with a holden setup, since jza80 n.a. flywheels are so damn hard to find (and exxy)!
    thanks again.
    oh true!
    thanks again.
    No real advantage,
    Possible advantages could be lighter flywheel, larger friction area for clutch and better clutch tho. You'll have to decide what you want to do, which will also depend on the power level that you want
    yeah i see. think the current setup only has a 220mm clutch diameter. But yeah since its a w58 i'm not gonna go for much power, just want this thing back on the road as soon as i can.
    Thanks alot for the help wilbo! i'll rep you when i can
    Junior Member Grease Monkey DRIFTAMK3's Avatar
    Jul 2008
    No real advantage,
    Hey man so i take it you have w58 behind your 1j if you do man wat power has it held up to the most i have seen them take from the 1j is about 280rwkw but having said that i haven seen that many either at that level
    I say this because im puttin a 1j in my GA and am undesided wat box 2 use would like R154 but the price i cant justify just yet
    Quote Originally Posted by DRIFTAMK3
    I no longer have a 1jz
    But yes I did have a 1jz with a w58 It was quite mild however around 200rwkw would have been my guess. It did have a twin plate clutch however which wouldn't have been the nicest thing for the rest of the drivetrain.
    However it is worth noting that I broke a diff, but never a gearbox...in a lighter MA61 tho
    Jul 2008
    No worries man thnks for the advice ill have to way pros for cons
    +rep for the help
    Quote Originally Posted by shelldrake
    ARP do both metric & imperial bolts.
    I was talking about the pp > flywheel bolts being imperial.
    Although... would anyone be suprised if dellow retapped a crank?!
    Glad you got it sorted Hash.
    Phil
  1. clutch problems
    Last Post: 06-03-2007, 05:48 PM
  2. Clutch Problems
    By Buttocks in forum Tech and Conversions
    Last Post: 02-09-2006, 10:12 AM
  3. Clutch fork problem
    By Spode in forum Tech and Conversions
    Last Post: 21-08-2006, 11:30 PM
