Results 1 to 15 of 24
Thread: Single Turbo Conversion
    Sep 2008
    S.A
    Default Single Turbo Conversion
    Can anybody tell me what i need to convert my twin turbo 1g-gte to a single turbo GT3071R?
    Default Re: Single Turbo Conversion
    a manifold, dump pipe, modified oil and water lines, new cooler pipes, thats about it really, you can on and on though if wanted, like computer and injecters ect ect, but not required if you dont want too, depends how much power you want, or what you want to do really
    cheers steve,
    1ggte, 11.22 @122mph
    Sep 2008
    S.A
    reasonable power but keeping it stable without too much lag.
    Toyota fanatic Grease Monkey Gttwinturbomk3's Avatar
    Jun 2007
    Dunedin
    Dont forget you prob want a decent external wastegate too. And then once you have your turbo setup, to get the best from it all and your moneys worth you really need computer bigger fuel pump and injectors and some real good tuning! So all up well over $5000.
    I suggest concentrating on a good base motor for starters then concider more power after that. A good rebuild is highly benifical before doing any of the above. Unless you want to watch your 1g make over 300rwhp then bugger out because of age.?
    Sep 2008
    S.A
    can u give me any advice on a new rebuild?
    wat do you want too know about the rebuild?
    all parts for a rebuild are available
    cheers steve,
    Sep 2008
    S.A
    the basics of rebuilding a 1g or any advice you can give
    Junior Member Grease Monkey DRIFTAMK3's Avatar
    Jul 2008
    for starters
    new gasket kit thermostats
    front and rear main seal
    spiggot bearing
    possibly machined head dependin on condition
    freshly honed cylinders
    pistons rings
    head stud kit
    prob stick wit stock conrods they are massive to begin wit and pretty indestructable
    lol
    big end bearings
    little end bearings
    new oil pump+ water pump
    new pulleys + hamonic ballancer +new belts
    timing belt
    linished cams
    reground crank
    replace original engine nuts and bolts
    Off the top of my head thats all i can think off and i hope it helps... there is a lot more invovled but thats all i can think off at the moment
    but well worth it man im currently considerin rebuildin mine as well let me no how you go
    Jul 2008
    and welcome by the way
    and as for the crank and cams if yours are still in pretty good condition they should be fine but have them inspected by whoever does the rebuild just to be safe
    Sep 2008
    S.A
    cheers man and thanks for all the advice.
    Sep 2008
    S.A
    and any chance you know were id be able to pick most of the stuff up from?
    Jul 2008
    to be honest i couldn tell you evrything but as far as i no
    repco for the timing belt ask for a gates timing belt bout $110
    any goodbearing shop for your bearings and possibly seals
    except big and little end bearings
    although i have done the front and rear main seal + spiggot bearing ill try to find the part number for ya
    whoever you get to see over the rebuild should be able to get most of the enternal work done(performance shop or a good enginering shop)
    water pumps bout $190 from toyota
    unsure on oil pump
    or try the search feture on toymods there will most prob be previous thread wit wat your lookin for hope that helps
    im putting a gt30 on mine and intend on boosting it up to about 17 psi, im not going to rebuild it though at this stage as i need to get the car back on the road asap
    the motor has been sitting in the bay for about 12 months, it still cranks, but i know eventually i will need to do rear main seal as it is already leaking a bit and when i do i will replace those other things
    i reckon i'll just do oil filter (i have a romote mount jigga), timing belt and other obvious bits
    im not going to go stupid building a 1g from the bottom up as for the money its far cheaper to get a 1uz or 1j
    please let me know if ive left anything major out
    Jul 2008
    yeah that is true also i suppose it comes down to each to there own i suppose i would love to get a 1j but got to much of a soft spot for the 1g at the moment ...
    dude nice turbo choice wat size rear housin on the gt 30 are you gonna run
    i was lookin at one my self or a gt30-40r gt35 or gt30 wit 0.63 rear all at about 17psi
    Or gt30-76r 0.82 rear at 19psi would be nice to would be happy to make around 300whp
    which would be nice lol
    its the gt3076r with a 0.63 housing
  1. **HELP** Twin turbo to single 1jz setup.
    Last Post: 11-07-2011, 12:06 PM
