Results 1 to 6 of 6
Thread: help i hope i havenn't F'd up!
    Mar 2008
    Default help i hope i havenn't F'd up!
    Ok i have bolted up a pari of MX62 cressida struts in to my KE55.
    i have stock control arm.
    i've heard about stub angles!
    is this gonna affect my camber?
    eg make it positive?
    Default Re: help i hope i havenn't F'd up!
    I have no idea about the difference between the struts but I'd say with a bit of thinking you can work it out, if the MX62 struts are longer from top to hub mount and carry springs greater than or equal to in stiffness, with the same control arms it'll be like having a lift kit on the car.
    But if you've already done it then can't you tell by looking at it? Park on a flat surface and use a right angle ruler if you have to.
    Mar 2008
    ok well my car is on chssis stands. with a 20v conversion underway
    i'm using lowered ke55 kings springs.
    i'm can't currently see if it gonna f up.
    i had a mate use these struts in his car but he had sigma LCA's i wanna keep my stock ones. cos i've put new bushes and balljoints inem
    Well its not like its irreverseable.
    If you don't get an answer, continue and let us know the outcome.
    Mar 2008
    yeah it is reversab;e but i've spet approx $400 bucks on rebuilding em!
    might have to bite the bullet and get some cambertops!
    the guys on rollaclub might be able to answer this for you...
    Now - RA23-WRX
