Results 1 to 7 of 7
Thread: 18r-g in Ta22
    Too old to be a Grease Monkey
    Aug 2008
    Default 18r-g in Ta22
    Hey all,
    I know this has been discussed a bit in old threads but I am interested in whether when putting an 18RG into a TA22 the front sump of the 18 R corona misses the TA22 mid mount engine cross member?
    I take it that the front oil pick up would be ok too?
    Anyone who knows this, your opinions would be greatly useful.
    Nathan
    Aug 2008
    Default Re: 18r-g in Ta22
    Anyone? Someone has to have an opinion?
    Nathan
    Noof,
    I had an 18rg in a ta22 celica once upon a time. It had a front sump on it, and it did not hit the crossmember or the sway bar. No sure if it was a corona one but most likely.
    The engine does sit further forward than the 2t. ~100mm forward of the crossmember (18rg engine mounts sit ~100mm forward of the standard 2t crossmember from centre to centre.
    Roger
    Aug 2008
    Thanks Roger,
    Did you use custom engine mounts because as I see it I dont think that the 18RG engine mounts are going to allow the engine to sit in the right place?..
    I guess it isnt too hard to have some slightly adjustable engine mounts made up?
    More specifically? How did it go?
    Nathan
    Junior Member 1st year Apprentice rabbits's Avatar
    Aug 2006
    Noof i have a 18rg in my ta22 celica and the front bump sump is out of a rt104 also they come out of a rt114 and rt118
    You need a Ra21 Crossmember you can get them from classic_celica.com or you have to fabricate/ modify you standard ta22 crossmember. The mounts need to move forward also you need a tailshaft and gearbox crossmember from a automatic ta22 celica to fit 18rg. I bought the crossmember off Toymods i put a add on parts wanted
    Hope that helped
    Cheers Aboudy A.K.A rabbits
    Aug 2008
    Thanks Rabbits,
    I am looking at whether this is viable for me to do or whether I should hang out and wait for a 2TG... which is a little easier to fit?
    Might be a case of whatever happens first.
    Still thanks for the info.
    Was hoping to get by without modding the engine crossmember cos that is a PITA for me.
    I can get all the other parts required.
    You wouldnt happen to have any photos of your TA22 engine bay? Showing in particular the engine mounts? I have a design I have been thinking of but not sure?
    Nathan
    Aug 2006
    Hi Noof, mate you also have to cut out a hole for the gear stick because its lower. I reckon you stick with the 2tg alot less hassle all you have to do is Exhaust everything bolts straight on
  1. strut brace for a TA22
    By ca_celica in forum Tech and Conversions
    Last Post: 11-04-2014, 10:55 AM
  2. ma61 diff in a ta22?
    By weapon x in forum Tech and Conversions
    Last Post: 19-04-2006, 11:25 PM
