30psi, I'll give it a shot, just to make you happy.
Nim, yes, it is richening up, that is quite obvious to us. Quite frankly I don't see the point of doing a dyno run to confirm it. It's a stock ECU, meaning there is no kind of A/F ratio tuning that can be done.
ECU isn't going into limp mode and gives no error codes on diagnostics mode (we used to have a misfire problem (shit plugs), was so cool, the check light would flicker every time it misfired heheh).
We do have an o2 sensor, which actually should detect the carbon and lower the ratio... Might try changing that. I had another thought yesterday that it could be the TPS, as it's a TPS for a late model AE92 bigport, and the resistance at certain throttle points seems different than with an early TPS.
No knock sensor Nim, only 4AGZE's had those.
Kev.
