Results 1 to 15 of 18
Thread: TA22 Fuel Pickup question
    Junior Member Grease Monkey The GW's Avatar
    Ballarat
    Default TA22 Fuel Pickup question
    Some of you may know i am experiencing a fuel problem with my ta22 in a 3tgte, car has pre pump to surge tank then main pump to fuel rail.
    The following photo is shot from underneath and the forward most part of the fuel tank (towards engine). I just want confirmation which is the pickup and which is the return?
    I'll go from there, thanks
    1984 SA63 Celica - RIP , 1979 Ford XD - The Lunar Lander
    1972 TA22 Celica - Project Car ,1986 ST162 Celica SX - Gone
    1985 RA65 Celica - Me & ryleys rally car
    1974 TA22 Celica - Current project, 1972 TA22 - Wetish
    Junior Member Domestic Engineer TA22 GT's Avatar
    Default Re: TA22 Fuel Pickup question
    From memory both lines are internally the same, eg they both go to the base of the tank.
    Simon
    Junior Member Backyard Mechanic ONCE-NA's Avatar
    Can anyone confirm this?
    Last I checked both lines DO NOT go to the base of the tank. mmm I can't remember which side is which.....
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Ballarat
    ah shit...um anybody help us out here?
    If we could find a standard carby car and trace the line through...
    Yeah only one goes to the bottom of the tank.
    Pull the hoses off and blow into them. If you hear the fuel bubbling that's the one that goes to the bottom.
    Insert whitty comment her Automotive Encyclopaedia blacktop's Avatar
    Aug 2006
    correct me if im wrong but the one with the filter hanging of it would be pick up line,
    wouldn't it?
    Dec 2006
    GW,
    I have just had a look in my spare tank and both lines go to the bottom of the tank.
    When looking up from under the car,where the fuel lines come out above the diff, the carby supply line is the one closest to the wheel.
    Hope this helps,
    Wheelie
    Built! not bought Grease Monkey SYC02T's Avatar
    Go with the blow in one of the lines, and listen for bubbles.
    Your car is the floor mounted tank from memory. The lines go into the tank at the same height, but one goes to the bottom of the tank. I will try and have a look at mine tommorow, if this bloody rain/flooding stops.
    If your not living on the edge,
    Your taking up too much space!!!
    wheel rim: which wheel was that?
    Dec 2006
    The tank I am refering to is the standard TA22 tank.I can't see the top of the tank that is in the 22 because it is behind the amp panel. Where the lines come out under the car above the diff the line on the outside closest to the rear drivers side wheel runs to the engine bay then bends around to face the firewall.
    Wheelie.
    That Photo deffinatly shows the 70 - Early 72 Floor mount tank. Not the late model behind the seat tank.
    Ok, just went and physically checked my spare tank, connection nearest to drivers side rear wheel in the early underfloor type tank is the pick up, return line is closest to passenger wheel and does not go to bottom of tank but is straight pipe to return fuel about 3/4 way up the tank. This is from a 71 model ta22.
    Hope this helps
    Regards
    Greg
    71 ta22 2tgeu,ke35 18rg, ke 35 3k auto,74 ta22 2tg,73 ta22 2t,80 ra40 18rgeu,92 kawasaki gtr1000,95 nj pajero, 2011 jeep patriot,2011 aricat jd495,1979 leyland motorhome (350chev),1995 Mitsubishi Delica
    Too many cars so little time
    Ballarat
    thanks very much schnitzel much appreciated. yep, pic was from an early model tank like yours. thanks heaps for everyones input!
  1. TA22 Fuel Line questions?
    By Ta22boy in forum Tech and Conversions
    Last Post: 22-08-2006, 05:32 PM
  2. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
