Results 1 to 6 of 6
Thread: 1G-fe wiring required
    Sep 2008
    Pakistan
    Default 1G-fe wiring required
    does any1 has a wiring diagram for this engine.
    + trying 2 locate coolant sensor also
    TAS
    Default Re: location of coolant sensor in 1g-fe engine
    If it is like a 1GGTE, there are two plugs on the left side of the engine (looking from the front) up the top, underneath the distributor.
    I am only using one of these sensors with my aftermarket ecu, I can't confirm whether both are water temp.
    Tallahassee, FL USofA
    Quote Originally Posted by nomi01
    pls help me locate coolant sensor in 1G-Fe.+ does any1 has a wiring diagram for this engine.
    I'm guessing that there is one for the dashboard warning/idiot light or gauge, one for the FI, maybe one for the cold start system and one for the cooling fans. Even with the differences between those with the thermostat located on the engine's inlet and those on the outlet, there isn't much difference in location.
    If you're looking for the gauge/idido light, I'd guess that it is somewher on the engines water outlet, the upper radiator hose, and that it only has one terminal. What happens on the the dash when the sending unit/sensor is disconnected, the one with the single terminal? What happens when it is shorted to ground or connected to a test meter or test light?
    Sep 2008
    Pakistan
    @ stefan
    nothing around distributer.
    @ allencr
    there is one sensor with 2 wires at upper radiator hose.both wires r ground(checked with ohmeter).i removed the plug but the dash guage still works.removing plug or shortening it has no effect on electric fan,it remains off.cudnt find anyother thermo sensor.
    any1 got idea where is the other sensor located??
    TAS
    So it doesn't have the plug you can see below the distributor in my pic? Hmm.
    Sep 2008
    Pakistan
    any1 got wiring diagram for 1G-fe.it wud be vry helpful 4 me to sort out the problems im facing.the car is sitting for 2 weeks its the only ride in town(im in pakistan) nd mechanics dnt know a bit abt this car..
  1. 4age 20v Silvertop - Check engine light?
    By Macross in forum Tech and Conversions
    Last Post: 29-09-2010, 09:45 AM
  2. Engine and Coolant Temp issue
    By Vios-GT_07 in forum Tech and Conversions
    Last Post: 18-09-2007, 02:05 AM
  3. Cooling Systems - Overheating Problems.
    Last Post: 24-06-2006, 09:40 PM
