my engine is 18R (steel head, non-crossflow) with ex-RB20 turbo (T3 I think) and 4AGZE injectors (365 cc/min). ECU is running MsExtra HiRes code (sorry, can't remember which version). Some more info is in the link in my Sig.
I tro to have it idle at or above 850rpm to keep oil pressure up and air-flow into motor fairly fast - the injector placement is not good at all and this makes for poor response when not on boost or at low rpms.
At idle, it can run >20 degrees advance at idle.
These maps are from the Dubbo drive back in 2007 so have been improved a bit since.
Fuel:
Spark:
AFR target map (needs WB sensor to be used):
Accel (was still not good at low rpm/off boost):
This is the MSQ file from that time
