Every blokes after a longer one !!!!!!!
have you worn it out allready steve
Hey, im having some dramas with clutch master cylinder i belive.
I have a new clutch, only about 5000km old (hard 5000km tho)
and only had to adjust it once, and already i have run out of adjustment on the pedal, clutch is all the way off the floor and sometimes has problems dis-engaging.
Yes it is bled properly,
and the drama i belive is after looking at a stock jza70 master cylinder it is alot longer, therefore more fluid and throw?
Maybe my stock RA28 master needs to be replaced with something bigger?
Has anyone else ever has a problem such as this?
Any ideas welcome!!
It is a brass button 9 puck and an R154
Stock r154 slave cylinder (not leaking)
and Stock ra28 master cylinder.
Thanks
Steve
Cheers, Steve
1jz ra28 - AKA - Tyer Fryer
1984 ma61 - stock and slow- ACE condition
Cheers Dave
1977 RA28
1972 TA22
1984 Supra
lol. i think i need an extension! lol
Cheers, Steve
Drama is right!Originally Posted by 77GZE
The amount of fluid will only change with the diameter of the clutch MC or a change to the amount of travel from its push-rod, not the cylinders length.
Does it bottom out?
i had big problems with the original slave that i was using with the dellow kit i bought for the 1JZ. the pedal pressure was so high that it blew the seals out of the master cylinder every month.
in the end i put a massive slave off a land cruiser (15/16's i think) on it to reduce pedal pressure.
the result of this is that i have quite long pedal travel but not excessive, and the original celica (AE86) clutch master is up to the job of supplying enough fluid for this big slave.
might be something else????
sheepers.
69 MS51 crown coupe. http://www.toymods.org.au/forums/sho...980#post835980
RA23 celica with 1JZ-GTE. http://www.toymods.org.au/forums/sho...sheepers+jza23
76 RA28 celica 1UZ, http://www.toymods.org.au/forums/showthread.php?t=12299
