Results 16 to 26 of 26
Thread: 1JZ waterpump, that little hole underneath...
    vic
    Default Re: 1JZ waterpump, that little hole underneath...
    If we are talking hydro water pump and you undid the 4, 14 mm head bolts at the front it buggers up the seal a bit and should be replaced .
    Dave
    West Australia
    jztoyn + Todd
    Just recently did this on my JZA70R 1JZ in my soarer, ass loads of pics in my thread (about 4 pages back now)
    i followed this:
    http://www.toymods.net/forums/showth...z30+100k+guide
    Few very super minor things are different between JZA70 and JZZ30
    the 3 complete flushes were done without the rad cap so thats good. it appears to have sealed after just the first flush which i didnt even get to properly warm the motor.
    it is the hydro pump but no i didnt try to seperate the hydro housing from the waterpump housing.
    thanks Coffmeister.
    JZA70|R / 12.45 @ 111 mph.
    Tallahassee, FL USofA
    Quote Originally Posted by JZA70 R
    ... it appears to have sealed ,,, didnt even get to properly warm the motor.
    To me it's the friction without the coolant lubeing it and I don't think the heat has any effect on it at all.
    Apr 2007
    Keep an eye on it because coolant ( glycol ) has a capillary action to it & will sometimes cause it to leak again if its not 100 % leak free, but if it does just do the pellets as i mentioned & pretty sure it will be fine then ....
    Western Aus
    toyota red is a self sealing coolant, so shouldnt it sort itself out?
    (this is in response to lexsmaz, not you toddo.)
    The hole is so water doesnt get into the bearing and:
    1. Push the pulley off the shaft
    2. Make the bearing seize.
    Junior Member Grease Monkey seamonsta's Avatar
    May 2007
    Hills Area Sydney
    Old thread revival, but I need to know if the pellets from Holden don't work is there anyway of repairing the old seal if the pump assy comes off the motor, or is it just throw away and get a new one? I have a JZX90 motor and it has the hydro fan setup as well so the waterpump is $400+ from Toyota. Anyone repaired one? (no i don't want to switch to thermo fans and get a 2J waterpump, I like the Hydro fan).
    Tim
    Quote Originally Posted by wilbo666 View Post
    My understanding is that water comes out of that hole when the seal fails.
    It indicates that the pump seal has failed.
    I know this is a thread dig but i'd might as well reply to say that yes, this has happened to me (albeit on a dirty holden v8) - just replaced the pump
    May 2007
    Hills Area Sydney
    Not that simple as the waterpump with Hydrofan incl is over $1500 apparently from Toyota after some more searching, I could get a whole motor for less than that!!
    Sorry, my reply wasn't directed at you so much
    If you can handle secondhand, i'm sure plenty of people get rid of them
    quick search shows this guy
    http://www.toymods.org.au/forums/sho...1jz+water+pump
    dont know if they suit?
  1. Idiots guide to a 1jz conversion into a MA70 bodied supra.
    By Xistant in forum Engine & Driveline Conversions
    Last Post: 12-07-2019, 05:11 PM
  2. 1JZ ECU capacitor replacement info
    Last Post: 17-05-2017, 09:37 PM
  3. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 07:13 PM
  4. JZX81 1JZ: Analogue Dash Wiring
    By mamba in forum Engine & Driveline Conversions
    Last Post: 19-05-2007, 04:04 PM
  5. 1jz vs 2jz heads
