MX13 diff is an 3.9:1 F series - will handle the power no probs. Plenty of different ratios but I suggest you get it going, see how it drives and then pick a more suitable ratio. LSDs are out there.
Which Cressida box? Speedo cable, need to know which box! You might find that a 90 degree angle from an MA61 will help with curves and space. Cross member - you could use the one that came from the auto or an MX13 one. Bolt two bits of thick angle iron to extend backwards and bolt cross member to those.
7M will have 4 or 5 wires that need power - the power required to those wires will either be full time, ignition on or starter on. You splice those wires from the MX10 loom. Wiring diagram is your friend.
Alternator wiring will be different (internal reg versus external reg) so you'll need to sort that out too. There is a thread outlining how to do that so search.
