Results 1 to 12 of 12
Thread: 4agze Ignitor** WHat else can i use
    Default 4agze Ignitor** WHat else can i use
    Does anyone know if i can use another model ignitor other than the 4azge toyota part : 89621- 10230
    or if you have a 4agze running.. what model ignitor are your runnin???
    Please assist a poor guy to get his spoonta on da blaktop.
    -Driftin DA' 86 Since way back -
    Nice..... Grease Monkey Rex_Kelway's Avatar
    Default Re: 4agze Ignitor** WHat else can i use
    If you cant find one, ring Petroject here in SA on (08) 8132 1622.
    They can in all likelyhood provide you a two channel ignitor or even make you one from scratch.
    the only other on i know that works is one from a 7mgte
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    thanks EVERYONE!
    i got a 7mgte from a wreckers for $70.00
    better than the toyota model original from japan for $748.00
    boo ya!
    the 7m-gte will not work DIRECTLY the same......
    .....the witzl predicts much pain forthcoming from this thread....
    OH MAN!
    What differences will i see in the use of the 7mgte? when you say .. wont work directly the same??
    do i need to change something else to make it work the same??
    the 4agze has a 2 channel output, whereas the 7m-gte has a 3-channel output. (2 coil packs vs 3)
    4A-GZE Ignitor
    • IGt (fire signal from ecu)
    • IGf (confirmation of ignition to ecu)
    • IGd (channel selection signal from ecu)
    • +B (power from EFI main relay)
    • IG- (tacho signal)
    • IGc1 (coil1 negative output)
    • IGc2 (coil2 negative output)
    7M-GTE Ignitor
    • IGdA (channel selection signal from ecu)
    • IGdB (channel selection signal from ecu)
    • IGc3 (coil3 negative output)
    There is a way to make it work.... you can thank the guys at club4ag for this one....
    http://www.club4ag.com/faq%20and%20t...-GZE%20DLI.htm
    ....... damn i'm getting sick of spoon feeding....
    WITZL!
    You are a GOD!
    and you have saved me $700.00
    you should become a full time Toyota Consultant!
    Cheers heaps for that dude!
    WITZL!
    Reputation added!
    if u get stuck i have a 4agze ignitor for sale
    make an offer and ill see if its ok hehe
    $70??? and ill pay postage???
    i dont care if i sell it or not
    but i do know they go for 150 cause no one has em
  1. 4agze conversion
    Last Post: 02-03-2006, 09:52 PM
  2. 4AGZE into AE102 Corolla
    By birdie in forum Tech and Conversions
    Last Post: 02-02-2006, 06:35 PM
  3. oil capacity in 4agze
    By mojo_type in forum Tech and Conversions
    Last Post: 26-01-2006, 09:29 AM
  4. How to connect 20V alt to 4agze loom?
    By d-shiznit in forum Tech and Conversions
    Last Post: 25-11-2005, 08:10 AM
