Page 1 of 5 123 ... LastLast
Results 1 to 15 of 65
Thread: 3SGTE coil on plug conversion
    queensland
    Default 3SGTE coil on plug conversion
    has anyone got any experiences with coil-on-plug conversions for 3SGTE???
    I've done plenty of external multi-coil conversions, but I'm looking at an alternative for my new race engine. The Caldina ones I've seen may not fit as the cam cover is totally different to Gen2/Gen 3 turbo covers I'm familiar with.
    any help/leads appreciated. thanks
    terry
    Apr 2007
    Default Re: 3SGTE coil on plug conversion
    yah been wondering this my self if you search google i have scene some one useing twin rx7 coils with varying sucess also what about holden coil packs?
    queensland
    the RX ones are external coils, not coil-on-plug. I assume the Holden ones you refer to are LS1 coils, which I have used, but they are also external coils, they just happen to get mounted on the cam covers in most applications
    Not much help,
    But have you had a look at 1NZ / 1ZZ?
    1MZ also springs to mind...
    do the cam covers swap over?
    Nov 2007
    What about motorbike ones? R6/R1 yamaha has 4. They may or may not seal in the cam cover (they are designed to but of course the dimensions vary).
    Ebay is your friend.
    Junior Member 1st year Apprentice tin can's Avatar
    From what i have tried on my gen2 1zzfe coil's work sit about 5mm above the rocker cover just enough to fit a alloy bolt so u can weld it on the rocker cover
    hope i have explained this ok.
    im not a Mechanic im a parts interperter
    current project: ke70 with 3tet
    now with 114kw on 10psi
    btw, i have spare caldina ones i can measure up if needed.
    caldina and 1zzfe and 1nz are the same length
    oh sweet
    are they same part?
    do they fit 4AG?
    no not the same part number different pin outs but same plug.
    but don't see why you cant use them.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    1MZ run wasted spark; 3 coils on the front bank with leads to the rear.
    Pretty sure 2AZ coils are the same as 1/2NZ ones.
    sure are the same Gavatron the bracket off the coil is the main different
    Adelaide, SA
    Yup. Got a stash of 16 from different changeover wrecker motors I've done at work. 8 2AZ ones and 8 2NZ ones
    ill but 4 of ya
    how muchie????
  1. MA61 5me to 5mge conversion guide
    By Enchanter in forum Engine & Driveline Conversions
    Last Post: 17-09-2013, 07:07 PM
  2. pressure tested and problems
    By 2revup in forum Tech and Conversions
    Last Post: 18-02-2008, 04:11 AM
  3. MA70 --> JZA70 Conversion
  4. Coil for High Energy Ignition
    By Tham in forum Tech and Conversions
    Last Post: 24-05-2006, 01:29 AM
  5. checking timing on car with coil on plug setup
    Last Post: 23-02-2006, 07:52 PM
