yah been wondering this my self if you search google i have scene some one useing twin rx7 coils with varying sucess also what about holden coil packs?
has anyone got any experiences with coil-on-plug conversions for 3SGTE???
I've done plenty of external multi-coil conversions, but I'm looking at an alternative for my new race engine. The Caldina ones I've seen may not fit as the cam cover is totally different to Gen2/Gen 3 turbo covers I'm familiar with.
any help/leads appreciated. thanks
terry
the RX ones are external coils, not coil-on-plug. I assume the Holden ones you refer to are LS1 coils, which I have used, but they are also external coils, they just happen to get mounted on the cam covers in most applications
Not much help,
But have you had a look at 1NZ / 1ZZ?
1MZ also springs to mind...
do the cam covers swap over?
What about motorbike ones? R6/R1 yamaha has 4. They may or may not seal in the cam cover (they are designed to but of course the dimensions vary).
Ebay is your friend.
From what i have tried on my gen2 1zzfe coil's work sit about 5mm above the rocker cover just enough to fit a alloy bolt so u can weld it on the rocker cover
hope i have explained this ok.
im not a Mechanic im a parts interperter
current project: ke70 with 3tet
now with 114kw on 10psi
btw, i have spare caldina ones i can measure up if needed.
caldina and 1zzfe and 1nz are the same length
oh sweet
are they same part?
do they fit 4AG?
no not the same part number different pin outs but same plug.
but don't see why you cant use them.
1MZ run wasted spark; 3 coils on the front bank with leads to the rear.Originally Posted by wilbo666
Pretty sure 2AZ coils are the same as 1/2NZ ones.
sure are the same Gavatron the bracket off the coil is the main different
Yup. Got a stash of 16 from different changeover wrecker motors I've done at work. 8 2AZ ones and 8 2NZ ones
ill but 4 of ya
how muchie????
