is that with cold oil? is normal..Originally Posted by lilcrash
when oil is at operating temp, the pressure will come down.... wait till oil gets hot first perhaps?
then when you rev it up (after oil is hot) it should reach a maximum around 3-4000rpm.. which is the internally regulated pressure (by the pump bypass)..
if it is still getting very high after oil is hot, then either you have a bung gauge/sender, or you have pump issues...
good luck![]()
so take out 5% fuel, see if it gets better.
