Results 1 to 15 of 24
Thread: Air flow meter to MAP conversion
    Default Air flow meter to MAP conversion
    Anybody know the relationship between airflow and manifold pressure in an NA engine.
    I assume the closer to atmospheric pressure in the manifold the greater is the airflow.
    What abour RPM?
    A wide open throttle at low rpm under load would produce near atmospheric pressure in the manifold but perhaps not high airflow.
    Default Re: Air flow meter to MAP conversion
    You've got a bit of electrical prowess,
    Why not make a device that has
    Inputs:
    >Airflow (existing AFM)
    >MAP (hook up the MAP sensor you want to use!)
    >RPM
    >TPS (I don't think this will really tell you much, but might as well log?)
    From that you should be able to construct a lookup table of sorts (or work out the equation ) to allow you to convert the MAP voltage to the expected AFM voltage!
    You're 100% that any box of tricks will need RPM, as you said, WOT at idle isn't as much airflow as WOT @ 6000rpm (but MAP should be similar ).
    Edit:
    In fact I might be able to lend you a box of tricks to do the logging if you want / need?
    Junior Member Backyard Mechanic manny's Avatar
    And if it gets too hard you can just try a MAP ECU
    GSE20 IS250 - daily
    UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
    UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
    Inputs:
    >RPM
    Edit:
    I've been building a box today that will give me an airflow meter and a MAP sensor output.
    The MAP I have is from a ford and converts the pressure into a square wave with the frequency varying from about 80 to 160 Hz.
    I also have a hot wire MAF from a holden that also gives a frequency output.
    I will bodge the whole thing together with duct tape and compare the outputs.
    I might take you up on that offer of the data logger. I'll get back to you when I decide which way to go.
    User Conversion King
    NWA
    you might need intake air temp as im pretty sure a AFM would measure air mass flowing through it.
    jaycar have those 128 load point 5v signal adjusters too
    hello
    NWA
    http://www.geocities.com/MotorCity/P...ject/AFMs.html
    small amount of relevant info there
    hello
    Quote Originally Posted by brett_celicacoupe
    Thanks for that link. The toyota traindocs just show voltage output versus flap opening angle. Voltage versus airflow is more useful.
    I also forgot about the JAYCAR adjuster. It might be the cheapest solution of all.
    DO you know if the JAYCAR unit will accept a frequency input??
    Can I ask why you are using a MAP sensor that outputs a frequency as opposed to the generic type that outputs an approx 0-5V signal?
    Seconded. Just get a normal one, the voltage will be much easier to play with than a frequency.
    I just happened to have a ford one. I didn't realise that other MAP sensor were more simple.
    Can I ask what models use a 0-5V unit? Are the cheapies on ebay the generic type?
    Quote Originally Posted by amichie
    It doesn't.
    Almost anything else!
    I've got a GM one and plug I'll send you for the cost of postage if ya want?
    Yes please. PM me some details and I will direct deposit. Since my car is NA I think virtually anything will work. I would love to try and move it around the intake to try and figure out where any restrictions might be. I have long suspected MY LPG carb as a major restriction. I'd love to know the pressure drop across it.
    http://www.autospeed.com/cms/A_110210/article.html
    these kind of MAP sensors (MPX4250 etc) are cheap... well.. about $15-20 from digikey. same as used in Megasquirts
    http://www.freescale.com/files/senso...t/MPX4250A.pdf
  1. MA70 --> JZA70 Conversion
  2. MAP computer on AFM engine with e-manage?
    By timgte in forum Tech and Conversions
    Last Post: 04-10-2006, 09:58 AM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
