You've got a bit of electrical prowess,
Why not make a device that has
Inputs:
>Airflow (existing AFM)
>MAP (hook up the MAP sensor you want to use!)
>RPM
>TPS (I don't think this will really tell you much, but might as well log?)
From that you should be able to construct a lookup table of sorts (or work out the equation) to allow you to convert the MAP voltage to the expected AFM voltage!
You're 100% that any box of tricks will need RPM, as you said, WOT at idle isn't as much airflow as WOT @ 6000rpm (but MAP should be similar).
Edit:
In fact I might be able to lend you a box of tricks to do the logging if you want / need?
