Results 61 to 72 of 72
Thread: Why are BOV's so Expensive?
  1. #61
    Default Re: Why are BOV's so Expensive?
    Of course proper beaded pipes and good clamps would sort the issue too
    Yep I've got all that now, but at the time I was too cheap.
  2. #62
    Jul 2007
    i thought atmo bov's were illegal because they can affect your air/fuel ratio.
    most likely wrong though
  3. #63
    Quote Originally Posted by trdee
    only on AFM cars, doesnt effect a MAP sensored car
  4. #64
    Convictania
    I only by BOV's with the highest fps ratings. (flutters per second)
  5. #65
    It's noise that is unnecessary hence it being illegal.
  6. #66
    Quote Originally Posted by love ke70
    Technically speaking it's a 'change' to the emission system of the vehicle and therefore illegal...the reason is irrelevant.
    In practise for vented BOVs, it's noise and emissions (for AFM vehicles).
    so if running LPG which screams diplomatic immunity to emission system changes, it just comes down to noise?
    thanks for the info,
    cheers, andrew
  8. #68
    No idea on that one mate?
    Is the BOV pre or post mixer? or direct injection LPG?
    pre mixer
    mixer was bolted to mani.
    i think its reason enough for them to spot it and give the rest of the car a going over, and the atmo venting crankcase gasses are a bit of a no no so i think i might end up getting rid of it or going plumback, and fixing all the other things while im at it
  10. #70
    pre mixer
    Just lose it if you can mate, otherwise plumb back for piece of mind.
    TAS
    Quote Originally Posted by Draven
    stefan: what sort of noise are you getting? Normal BOV noise?
    My recirc BOV is, unfortunately, pretty bloody loud (which was the opposite of what I wanted )
    Sounds a lot like this, but louder (maybe my bov isn't working correctly... I'm new to turboed engines)
    http://www.youtube.com/watch?v=GmDpxmSHCHQ
  12. #72
    TAS
    Well, an update:
    http://www.toymods.net/forums/showthread.php?t=40293 My BOV was installed the wrong way around - now I now longer get the compressor surge noise, and, very weirdly, the overboost I was getting seems to be gone... :S
    I'm not sure now that my stock late mode EVO bov is up to the task. Now that it is working properly, it may be leaking boost, unless anyone has any other suggestions.
    Any more recommendations for non-overpriced, purely functional BOVs that are not noisy and don't leak?
  1. Alternative to the Expensive and Illusive JZ Clutch Fan?
    By sbyder in forum Tech and Conversions
    Last Post: 30-09-2007, 01:04 PM
  2. Alternative to the Expensive and Illusive JZ Clutch Fan?
    Last Post: 28-09-2007, 10:22 PM
