Results 1 to 11 of 11
Thread: 1jz tensioner pulley
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    Default 1jz tensioner pulley
    Hello!
    I'm having a few problems with my 1jz, the tensioner pulley seems to jam up if I tighten the bolt much more than finger tight.
    Does anyone have a picture of how it should look installed? Mine has the pulley and bearing slipped over the bolt hole bit, and the bolt + flange thing look like they hold it on. If it's tightened up and torqued it appears to be unable to rotate at all, but if it's loosened off just enough it'll spin freely. For the mean time I've used some of that temporary loc-tite to hold it at the point that seems to work best. Without the loc-tite it'll vibrate loose which is not a good thing
    Am I missing a washer or something? If needed I can grab pictures
    West Australia
    Default Re: 1jz tensioner pulley
    Hydra, just got a new pulley setup from japan sitting at home, will take detailed pics for ya
    but can only post em after work ~5pm WST
    Thats cool, thanks man!
    are you talking about the timing belt tensioner or the accessories belt tensioner?
    Which type do you have?
    Metal pulley or plastic pulley?
    Sorry guys, accessories tensioner. Plastic one
    There is a 'washer' on each side.
    The one with the larger hole goes to the rear.
    Thanks - perhaps I am missing the rear one then.
    Crap, that means I'll have to take off the belt...
    You must spread some Reputation around before giving it to wilbo666 again.
    Damn!
    so why are there plastic and metal ones, are the plastic ones aftermarket?
    ive got the metal one on my 1jz and my mate has a plastic one on his 1jz that is a bit chopped up and the bearing is a bit noisey.
    JZA70|R / 12.45 @ 111 mph.
    Quote Originally Posted by JZA70 R
    Toyota like to mix it up
    Both are factory
  1. JZX81 1JZ: Analogue Dash Wiring
    By mamba in forum Engine & Driveline Conversions
    Last Post: 19-05-2007, 04:04 PM
  2. 1jz to 2jz
    By HIZOKU in forum Tech and Conversions
    Last Post: 30-11-2006, 06:52 AM
  3. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
