Results 1 to 5 of 5
Thread: 3tc compression? (diff pistons)
    no backyard Domestic Engineer japlish's Avatar
    Default 3tc compression? (diff pistons)
    hi guys,
    i have a question regarding stock 3tc pistons: how many different oem versions were there?
    a friend and i recently picked up a 13t and it has different pistons to my mates old one and as far as i know they both had stock pistons?
    this is the top of the 13t one (piston NOT at TDC yet):
    and the top of a 3t one:
    now i know its impossible to get an exacting answer but does anyone know which one may have better comp?
    New Zealand
    Default Re: 3tc compression? (diff pistons)
    From memory, 13T pistons will not work with the 3T head and the 13T head is crap with a heap of emission gear.
    Callum
    Just by looking at the pistons I would have to say the 3T would have better comp. If you want to raise it up a bit more you could use the 2T head (smaller squish area) or in combination of decking the block and shaving the head plus using a thinner head gasket.
    deepdishfactory
    maybe the 13t dome is higher on one ide to make up the same comp as the 3tc piston?
    i was just going to deck the head, i've been told you can go as far as 2mm? (if the head has never been milled before)
    anybody know where to get a thinner HG?
    Jul 2008
    NSW.
    do you want some high comp forgies for it? my mate has a set he may sell cheap....pm me
  1. Hypereutectic Pistons
    By Celica_73 in forum Tech and Conversions
    Last Post: 28-04-2008, 09:45 PM
  2. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  3. Norminal Compression pressure of a 86mm bore 3TC?
    By CHB in forum Tech and Conversions
    Last Post: 11-05-2006, 04:12 PM
