Results 1 to 4 of 4
Thread: Clutch to suit lightened flywheel
    Dec 2006
    Default Clutch to suit lightened flywheel
    Finally found a Fidanza lightened flywheel to suit the 4AGZE. It has a quoted friction surface diameter of 228.6mm and a PCD of 249.5mm. Would I would need a custom clutch/pressure plate to suit or does anyone know of one which will suit this PCD?
    SC14 7AGZE Grease Monkey
    Jun 2007
    FL
    Default Re: Clutch to suit lightened flywheel
    What is a PCD?
    Can't help you much on if a custom clutch is needed, but I always thought the friction surface diameter of the 4AGZE clutch was 224mm.
    SC14 7AGZE build: http://beasted86.webs.com/
    http://en.wikipedia.org/wiki/Pitch_C...er#Bolt_circle
    Sounds like a fairly standard GZE clutch.
    Dec 2006
    Yea thanks I think a standard Exedy GZE clutch kit is a goer with a pressure plate that has a 250mm PCD. I think the accuracy of the quoted figures confused me! Cheers
  1. Lightened Flywheel Thread
    By 1200det in forum Tech and Conversions
    Last Post: 05-08-2008, 07:01 PM
